Hi Niklas,
It looks like when you have a constant in YY’s DOL it is only retrieved when the record initialises. Have a look at init_record() and process() in src/rec/boRecord.c.
So after the first time YY processes it’s VAL will remain at 0. One solution is the following. Another might be to set the DOL of YY to a record whose value is always one and FLNK XX to YY. If you only want YY to go high if XX is non-zero you could make ZZ
a calc record.
record(ao, "XX") {
field(FLNK, "ZZ")
record(bo, "ZZ") {
field(DOL, "1")
field(OMSL, "closed_loop")
field(OUT, "YY PP")
record(bo, "YY") {
field(HIGH, "0.5")
field(ZNAM, "Off")
field(ONAM, "On")
Damien
Dear all,
my name is Nicklas and I am a student at Uppsala University, Sweden, who is currently working for the research facility FREIA, which is designed for research and development of accelerators and instrumentation for accelerator based research.
I am new to epics so I would really appreciate some help.
Now to my question; as the subject line suggests, I need help/tips on how to generate a binary output pulse by processing an analog output record, i.e. I want the bo value to be 1 for 0.5 seconds (and then return to 0) each time the analog output is processed.
My idea of the database setup was the following:
field (OMSL, "closed_loop")
This works fine the first time "XX" is processed (using dbpf), but the next time "XX" is processed (using dbpf), it doesn't work.
Any tips/thoughts on this would be highly appreciated.
Engineering Physics Student at FREIA
Generating a 'binary output pulse' by processing an ao record? Nicklas
RE: Generating a 'binary output pulse' by processing an ao record? Arnold, Ned D.
<2014>
2025
2026
saveData vs 2G file size limit Mark Davis
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
