On 06/30/2014 10:27 AM, Mark Rivers wrote:
> Setting pact=TRUE seems to be the accepted solution for unrecoverable
> errors in device support init_record.
I agree. The extended device support mechanism that allows changes to
hardware link addresses and device types at runtime also sets PACT to
mark a record for which the device support has rejected the address (it
will clear PACT if a device support accepts the record).
The Asyn device support routines are not currently using this extended
support though, so you can't change the INP/OUT field of a record that
is configured to use Asyn, or switch from another device support to an
Asyn one at run-time.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: What to do when device initialisation fails Mark Rivers
- What to do when device initialisation fails nick.rees
- RE: What to do when device initialisation fails nick.rees
<2014>
2025
2026
<2014>
2025
2026
