> The Asyn device support routines are not currently using this extended support though
Krzysztof Lazarski actually started this at an EPICS Codeathon way back in 2008, but I've never gotten it incorporated into a release. I'd like to aim to get it into the next (4-24) release. That would be a good time to make the error handling of input and output links consistent and correct.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, June 30, 2014 10:47 AM
To: [email protected]
Subject: Re: What to do when device initialisation fails
On 06/30/2014 10:27 AM, Mark Rivers wrote:
> Setting pact=TRUE seems to be the accepted solution for unrecoverable
> errors in device support init_record.
I agree. The extended device support mechanism that allows changes to
hardware link addresses and device types at runtime also sets PACT to
mark a record for which the device support has rejected the address (it
will clear PACT if a device support accepts the record).
support though, so you can't change the INP/OUT field of a record that
is configured to use Asyn, or switch from another device support to an
Asyn one at run-time.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- What to do when device initialisation fails nick.rees
- RE: What to do when device initialisation fails Mark Rivers
- RE: What to do when device initialisation fails nick.rees
- Re: What to do when device initialisation fails Andrew Johnson
Problems using devSnmp from NSCL Florian Feldbauer
<2014>
2025
2026
Re: What to do when device initialisation fails Benjamin Franksen
<2014>
2025
2026
