1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems using devSnmp from NSCL
To: [email protected], EPICS Tech Talk <[email protected]>
Date: Tue, 01 Jul 2014 16:00:02 +0200
Hey John, hey all,
we have a Wiener PL506 low voltage power supply in our lab controlled via SNMP. I tried using the devSnmp module from NSCL (https://groups.nscl.msu.edu/controls/)
Nearly everything is working just fine, except for two records:
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadSwitchOnOff") {
  field( DTYP, "Snmp")
  field( INP,  "@$(CRATE) %{WCR}outputSwitch.$(CH) INTEGER: 100")
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadRegulationMode__" ) {
  field( DTYP, "Snmp" )
  field( INP,  "@$(CRATE) %{WCR}outputRegulationMode.$(CH) INTEGER: 100" )
$(CRATE) is the IP-Address of the PL506, %{WCR} = "guru WIENER-CRATE-MIB::"
and $(CH) is "u0".
When I try to process these records, I get the following error:
epics> dbpf PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff.PROC 1
filename="../dbTest.c" line number=375
No such file or directory - dbPutField error
Any idea what's goning wrong here?
Another question to John: Is there a particular reason why e.g. mbbi/o(Direct) or bi/o records are not supported by devSnmp?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Prev: RE: What to do when device initialisation fails Mark Rivers
Next: autosave R5-4 Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: dxp R3-3 released Mark Rivers
Next: Re: Problems using devSnmp from NSCL John A. Priller
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
