1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems using devSnmp from NSCL
To: Florian Feldbauer <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 1 Jul 2014 20:20:49 -0500
I might be a little slow helping debug it, I'm away from work until July 10. Do the PV names you're trying to access show up in a 'dbl' command? If so, what shows up when you have the snmp driver do a dump of them? For example:
snmpr 2 PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff
will do a level-2 debug dump of PV/oid info.
The reason we don't support mbbo/i/direct (yet, anyway) is simply because the old snmp driver we based on version on didn't support it and we've never yet needed it. It's something we could add if there's demand for it (and time is available, you know how that goes).
On 07/01/2014 09:00 AM, Florian Feldbauer wrote:
Hey John, hey all,
we have a Wiener PL506 low voltage power supply in our lab controlled via SNMP. I tried using the devSnmp module from NSCL (https://groups.nscl.msu.edu/controls/)
Nearly everything is working just fine, except for two records:
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadSwitchOnOff") {
  field( DTYP, "Snmp")
  field( INP,  "@$(CRATE) %{WCR}outputSwitch.$(CH) INTEGER: 100")
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadRegulationMode__" ) {
  field( DTYP, "Snmp" )
field( INP, "@$(CRATE) %{WCR}outputRegulationMode.$(CH) INTEGER: 100" )
$(CRATE) is the IP-Address of the PL506, %{WCR} = "guru WIENER-CRATE-MIB::"
and $(CH) is "u0".
When I try to process these records, I get the following error:
epics> dbpf PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff.PROC 1
filename="../dbTest.c" line number=375
No such file or directory - dbPutField error
Any idea what's goning wrong here?
Another question to John: Is there a particular reason why e.g. mbbi/o(Direct) or bi/o records are not supported by devSnmp?
Best regards,
Florian
Re: Problems using devSnmp from NSCL Florian Feldbauer
Prev: sscan records Christian Pauly
Next: Re: sscan records Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems using devSnmp from NSCL Florian Feldbauer
Next: Re: Problems using devSnmp from NSCL Florian Feldbauer
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
