1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems using devSnmp from NSCL
To: EPICS Tech Talk <[email protected]>
Date: Wed, 02 Jul 2014 17:38:01 +0200
Changing the mask from "INTEGER:" to "(" fixed my problem.
Now everything works just fine!
Thanks for the help
  Florian
On 07/02/2014 02:07 PM, John A. Priller wrote:
The first thing I notice is that the "reply mask" from your INP field is set to INTEGER:, but that won't work parsing the reply string of "INTEGER: off(0)" because "off(0)" isn't an integer. Try using '(' as your mask:
field( INP,  "@$(CRATE) %{WCR}outputSwitch.$(CH) ( 100")
Whether that's what's causing your problem with dbpf to the .PROC I don't know, but it is a problem.
On 07/02/2014 01:47 AM, Florian Feldbauer wrote:
Hey,
yes both records show up, when I run the `dbl` command.
Also there is no error message at initialization.
epics> snmpr 2 PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff
devSnmp report
read task loops : 3034376 (49.8 per sec)
send task loops : 3034301 (49.8 per sec)
active requests : 0
  host wienerpl506
  SNMP version    : SNMP_VERSION_2c
  Max OIDS/req    : 32
  Get Queue items : 0
  Set Queue items : 0
  Active sessions : 0
    Group 'guru'
    Host             : wienerpl506
    Send count       : 56804
    Reply count      : 56804
    Error count      : 0
    Avg reply time   : 0.0 msec
    Best reply time  : 0 msec
    Worst reply time : 20 msec
    PV count         : 34
    OID count        : 20
    PVs:
    PV 'PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff'
    OID name         : WIENER-CRATE-MIB::outputSwitch.u0
    Host/Community   : wienerpl506/guru
    Set type         : 's'
    Special flags    : 0x0000
    Settings count   : 0
    Max data length  : 100
    Raw value string : 'INTEGER: off(0)'
    Reply mask       : 'INTEGER:'
    Value string     : 'off(0)'
    OIDs:
verifying devSnmp tasks are running...
  sendTask is alive
      sendTask_abort  : 0
      sendTask_exited : 0
      globalLastTick  : 2014/07/02 08:37:21
  readTask is alive
      readTask_abort        : 0
      readTask_exited       : 0
      readTask_inSelect     : 0
      readTask_fds          : 18
      readTask_block        : 0
      readTask_ignoreBlocks : 0
      readTask_timeout      : 9 sec 995935 usec
I've just noticed, that the record seems to update correctly but with a READ_ALARM. The record bo/longout combination for setting WIENER-CRATE-MIB::outputSwitch.u0 is working fine...
Concerning the mb/bi/o/direct records: for thinks like the switch on/off stuff it would be nice...(since you don't need the additional longin/out record anymore) originally I also wanted to use mbbiDirect for the outputStatus, but this has 20 bits, so in this case one needs the longin/calc records anyway...
Best regards,
Florian
On 07/02/2014 03:20 AM, John A. Priller wrote:
I might be a little slow helping debug it, I'm away from work until July 10. Do the PV names you're trying to access show up in a 'dbl' command? If so, what shows up when you have the snmp driver do a dump of them? For example:
will do a level-2 debug dump of PV/oid info.
The reason we don't support mbbo/i/direct (yet, anyway) is simply because the old snmp driver we based on version on didn't support it and we've never yet needed it. It's something we could add if there's demand for it (and time is available, you know how that goes).
On 07/01/2014 09:00 AM, Florian Feldbauer wrote:
Hey John, hey all,
we have a Wiener PL506 low voltage power supply in our lab controlled via SNMP. I tried using the devSnmp module from NSCL (https://groups.nscl.msu.edu/controls/)
Nearly everything is working just fine, except for two records:
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadSwitchOnOff") {
  field( DTYP, "Snmp")
  field( INP,  "@$(CRATE) %{WCR}outputSwitch.$(CH) INTEGER: 100")
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadRegulationMode__" ) {
  field( DTYP, "Snmp" )
field( INP, "@$(CRATE) %{WCR}outputRegulationMode.$(CH) INTEGER: 100" )
$(CRATE) is the IP-Address of the PL506, %{WCR} = "guru WIENER-CRATE-MIB::"
and $(CH) is "u0".
When I try to process these records, I get the following error:
epics> dbpf PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff.PROC 1
filename="../dbTest.c" line number=375
No such file or directory - dbPutField error
Any idea what's goning wrong here?
Another question to John: Is there a particular reason why e.g. mbbi/o(Direct) or bi/o records are not supported by devSnmp?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29605         |
Re: Problems using devSnmp from NSCL John A. Priller
Prev: RE: sscan records Mooney, Tim M.
Next: Device support for a simple network ping Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems using devSnmp from NSCL John A. Priller
Next: autosave R5-4 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
