1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CS-Studio MacrosInput class documentation
Date: Wed, 2 Jul 2014 20:08:50 +0000
Note that the online help for BOY, Scripts, Access Widget lists this method:
public java.lang.String getMacroValue(java.lang.String macroName)
   Get macro value from the widget.
Parameters:  macroName - The name of the macro.
Returns:         the value of the macro. null if no such macro exist.
Example:        var macroValue = widget.getMacroValue("m1"); //get the macro value of "m1"
That would be the suggested way to read the value of a macro.
If you directly read the widget.getPropertyValue("macros"), as you noticed the result is of type MacrosInput.
It's not part of the script API which is documented, so you should try to avoid that, but if you insist, check its source code, https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/plugins/org.csstudio.opibuilder/src/org/csstudio/opibuilder/util/MacrosInput.java:
   value = parentMacros. getMacrosMap().get("name-of-macro")
Kay
On Jul 2, 2014, at 3:48 PM, Márcio Paduan Donadio <[email protected]>
 wrote:
> Dear all,
> I couldn't find the methods and properties list related to MacrosInput class of org.csstudio.opibuilder.util. I could find an example to insert items in the macro list, but could not find a way to read them.
> After parentMacros = widget.getPropertyValue("macros") I guessed the method could be parentMacros.get("item"), but an error message told me that get member was not part of the class MacrosInput.
> Could someone send me the specification of the class methods, please?
> Thank you very much,
> Computer Engineer - LNLS
CS-Studio MacrosInput class documentation Márcio Paduan Donadio
Prev: CS-Studio MacrosInput class documentation Márcio Paduan Donadio
Next: Re: Build EPICS for vxWorks 6.9 on windows-XP SP3 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: About FMB Oxford APD Detector zhuzwusst
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
