1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on VxWorks6.9
To: [email protected]
Date: Wed, 16 Jul 2014 14:27:17 +0200
On 16.07.2014 14:00, Dirk Zimoch wrote:
Newer C++ compilers consider more and more things in EPICS errors. And
maybe they are right.
The problem is
     T  * volatile * buffer;
in epicsRingPointer.h.
I am not sure if "volatile" really makes any sense here.
The other possibility is to cast away the "void" in the destructor.
delete [ ] (T*) buffer;
delete [ ] (T**) buffer;
Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
Dirk
epicsRingPointer.cpp
..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
: cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
*        Conversion loses qualifiers*
..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
class-template member function '__thiscall
epicsRingPointer<void>::~epicsRingPointer<void>(void)'
make[3]: Leaving directory
`C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
*/The following code is written in epicsRingPointer.h (line 93):/*
inline epicsRingPointer<T>:: ~epicsRingPointer( )
{ delete [ ] buffer; }
If anyone can suggest us the solution to overcome this error it will be
of help to us.
Amit Chauhan,
RRCAT, Indore
EPICS on VxWorks6.9 Amit Chauhan
Re: EPICS on VxWorks6.9 Dirk Zimoch
Prev: Re: EPICS on VxWorks6.9 Dirk Zimoch
Next: RE: EPICS on VxWorks6.9 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
