1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on VxWorks6.9
To: "'Dirk Zimoch'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Jul 2014 18:40:31 +0000
> The problem is
>     T  * volatile * buffer;
> in epicsRingPointer.h.
> I am not sure if "volatile" really makes any sense here.I strongly suggest NOT removing the volatile keyword.
In October 2008 we struggled with a very nasty bug in epicsRingPointer.h.  The symptoms were:
- Only failed on multi-processor systems
- Only failed with recent versions of gcc with optimization enabled
- Only failed 1 in 100,000 times
Eric Norum fixed the problem.  The changes included the following (comparison of epicsRingPointer.h from base 3.14.8.2 and 3.14.12.4)
-private: // Data
-    int nextPush;
-    int nextPop;
+private: /* Data */
+    volatile int nextPush;
+    volatile int nextPop;
     int size;
-    T **buffer;
+    T  * volatile * buffer;
So he added that volatile keyword, and it would need a lot of testing to prove it is not needed.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Wednesday, July 16, 2014 7:00 AM
To: [email protected]
Subject: Re: EPICS on VxWorks6.9
Newer C++ compilers consider more and more things in EPICS errors. And
maybe they are right.
The problem is
The other possibility is to cast away the "void" in the destructor.
delete [ ] (T*) buffer;
Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
Dirk
On 16.07.2014 08:14, Amit Chauhan wrote:
> Hi,
> We are trying to put EPICS on VxWorks.
> Various information related to our setup are:
>           EPICS base version : 3.14.12.4
>           VxWorks Version : 6.9
> Workbench version : 3.3
>           Host Architecture : win32 on x86
>           Target Architecture: ppc-32
>           Target Board :  MVME-5500 with PowerPC 7447 processor
> On running the 'make' command, the EPICS build stops after a while with
> an error.
> *_Following is the output of the make command:_*
> make -C ./configure install
> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure'
> perl ../src/tools/makeMakefile.pl O.win32-x86 ../..
> perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
> perl -MExtUtils::Command -e mkpath O.Common
> make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
> make[2]: Nothing to be done for `install'.
> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install
> `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure'
> make -C ./src install
> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src'
> make -C ./tools install
> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools'
> perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
> perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
> make[3]: Nothing to be done for `install'.
> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32
> install
> `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools'
> make -C ./makeBaseApp install
> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86
> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
> install
> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
> make -C ./makeBaseExt install
> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
> install
> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
> make -C ./libCom install
> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom'
> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
> perl ../../../src/libCom/misc/makeEpicsVersion.pl
> ../../../configure/CONFIG_BASE_VERSION ../O.Common
> Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
> Found EPICS Version 3.14.12.4
> "Installing generated generic include file
> C:\EPICS\base-3-14-12-4/include/epicsVersion.h"
> rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
> -I../../../src/libCom/osi/os/default -I..
> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
> -I../../../src/libCom/env -I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
> -I../../../src/libCom/logClient -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libCom/osi
> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
> -I../../../src/libCom/tsDefs -IC:\EPICS\base-3-14-12-4/include/os/WIN32
> -IC:\EPICS\base-3-14-12-4/include -fo Com.res ../Com.rc
> cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT
> -DEPICS_DLL_NO -I. -I..\\O.Common -I.
> -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
> -I..\\..\\..\\src\\libCom\\osi\\os\\default -I..
> -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring
> -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast
> -I..\\..\\..\\src\\libCom\\cppStd
> -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf
> -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env
> -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr
> -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash
> -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient
> -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc
> -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd
> -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs
> -IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32
> ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
> bucketLib.c
> cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
> -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I.
> ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
> ..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
> : cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
> *        Conversion loses qualifiers*
> ..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
> class-template member function '__thiscall
> epicsRingPointer<void>::~epicsRingPointer<void>(void)'
> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
> */The following code is written in epicsRingPointer.h (line 93):/*
> inline epicsRingPointer<T>:: ~epicsRingPointer( )
> { delete [ ] buffer; }
> If anyone can suggest us the solution to overcome this error it will be
> of help to us.
> Regards,
> Amit Chauhan,
> RRCAT, Indore
Re: EPICS on VxWorks6.9 Dirk Zimoch
EPICS on VxWorks6.9 Amit Chauhan
Prev: Re: EPICS on VxWorks6.9 Dirk Zimoch
Next: CSS is frozen after starts an external program Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS on VxWorks6.9 Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
