1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Formatting StreamDevice input
To: [email protected]
Date: Mon, 21 Jul 2014 14:36:04 -0400
I have a timer device that provides data over a RS232 serial interface. I’m using StreamDevice to grab the data and publish as PVs. The data contains several times. All the times come in as an ASCII string containing days, hours, minutes and seconds and I'm writing them to stringin PVs. However, the data does not contain any separators, so the data coming in looks something like 000024015 (i.e. 000 days, 02 hours, 40 minutes, 15 seconds). I know the ‘in’ command needs to match the incoming data exactly or else it is discarded, but is there a way to add formatting to the PV that is NOT in the data? All I want to do is add a ‘:’ separator between each part, so the PV value will be like 000:02:40:15. Any suggestions?
Thanks!
RE: Formatting StreamDevice input Mooney, Tim M.
RE: Formatting StreamDevice input Mazanec Tomáš
Re: Formatting StreamDevice input Dirk Zimoch
Prev: Re: EPICS alarming on VAL != X Jameson Graef Rollins
Next: RE: Formatting StreamDevice input Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
