1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Formatting StreamDevice input
To: [email protected]
Date: Thu, 24 Jul 2014 11:42:14 +0200
Hello Elmer
On 21.07.2014 20:36, Elmer Pensack wrote:
I have a timer device that provides data over a RS232 serial interface.
I’m using StreamDevice to grab the data and publish as PVs. The data
contains several times. All the times come in as an ASCII string
containing days, hours, minutes and seconds and I'm writing them to
stringin PVs. However, the data does not contain any separators, so the
data coming in looks something like 000024015 (i.e. 000 days, 02 hours,
40 minutes, 15 seconds). I know the ‘in’ command needs to match the
incoming data exactly or else it is discarded, but is there a way to add
formatting to the PV that is NOT in the data? All I want to do is add a
‘:’ separator between each part, so the PV value will be like
000:02:40:15. Any suggestions?
Thanks!
At the moment, it is not possible to insert additional characters while parsing a string. But this may be an interesting idea. You can use "%T(%j%H%M%S)" as suggested by Thomas to convert it to a double value (seconds) or to an EPICS time stamp with "%(.TIME)T(%j%H%M%S)", but not to a different string.
I suggest that you have a look at the scalcout record in SynApps.
http://www.aps.anl.gov/bcda/synApps/calc/R2-4/sCalcoutRecord.html
That can do string manipulation.
Dirk
Re: Formatting StreamDevice input Elmer Pensack
Prev: Re: StreamDevice, asynDriver or some other solution? Dirk Zimoch
Next: Re: EPICS alarming on VAL != X Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Formatting StreamDevice input Mazanec Tomáš
Next: Re: Formatting StreamDevice input Elmer Pensack
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
