1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS alarming on VAL != X
To: <[email protected]>
Date: Thu, 24 Jul 2014 11:47:31 +0200
On Thursday 24 July 2014 11:15:56 Dirk Zimoch wrote:
> On 21.07.2014 12:41, Benjamin Franksen wrote:
> > Why don't you just set DRVL=DRVH=<the desired value>.
>      /* check drive limits */
>      if (prec->drvh > prec->drvl) {
>          if (value > prec->drvh)
>              value = prec->drvh;
>          else if (value < prec->drvl)
>              value = prec->drvl;
> DRVL=DRVH => no check at all!
Strange. Not intuitive to me. And contrary to the docs. This is from the
RRM (https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Output#Desired_Output_Parameters):
The VAL field's value is forced to be within the limits specified in the
fields DRVH and DRVL, which are configured by the designer:
DRVL<=VAL<=DRVH
Note: If nothing is entered for DRVH and DRVL, the output value will
never change.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: EPICS alarming on VAL != X Andrew Johnson
EPICS alarming on VAL != X Jameson Graef Rollins
Re: EPICS alarming on VAL != X Benjamin Franksen
Re: EPICS alarming on VAL != X Dirk Zimoch
Prev: Re: Formatting StreamDevice input Dirk Zimoch
Next: [no subject] Tim Waclawski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS alarming on VAL != X Dirk Zimoch
Next: Re: EPICS alarming on VAL != X Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
