1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS alarming on VAL != X
To: <[email protected]>
Date: Fri, 25 Jul 2014 15:58:55 +0200
On Friday 25 July 2014 14:34:13 Dirk Zimoch wrote:
> Another alternative is to set default values DRVL=-Inf and DRVH=Inf.
I like this idea. It precisely captures the desired default behaviour
w/o imposing any artificial limitation. I guess the 'if (prec->drvh >
prec->drvl)' hack was from before +/-Inf was standardized.
BTW, does dbLoadRecords understand +/-Inf in a db file? Does
dbLoadDatabase in a record type field definition's "initial" property?
Cheers
Ben
> On 25.07.2014 14:05, Benjamin Franksen wrote:
> > On Thursday 24 July 2014 11:27:24 Andrew Johnson wrote:
> >> On 07/24/2014 04:47 AM, Benjamin Franksen wrote:
> >>> On Thursday 24 July 2014 11:15:56 Dirk Zimoch wrote:
> >>>> On 21.07.2014 12:41, Benjamin Franksen wrote:
> >>>>> Why don't you just set DRVL=DRVH=<the desired value>.
> >>>>       /* check drive limits */
> >>>>       if (prec->drvh > prec->drvl) {
> >>>>           if (value > prec->drvh)
> >>>>               value = prec->drvh;
> >>>>           else if (value < prec->drvl)
> >>>>               value = prec->drvl;
> >>>> DRVL=DRVH => no check at all!
> >>> Strange. Not intuitive to me. And contrary to the docs.
> >> That check predates the CVS history of the aoRecord.c file (1995).
> >> It
> >> makes perfect sense to me, there has to be a way to disable the
> >> clipping behaviour,
> > Hm, yes, that makes sense.
> >> and the assumption is that you would only create
> >> ao records for things that you want to be able to actually change.
> > In general, yes, but there are exceptions. I have used ao or ai
> > records to hold physical constants as parameters for a calculation.
> > It would be nice if I could tell the database to fix the value and
> > not even allow a db or ca put to change them. (One solution could
> > be a simple record type for such parameters. Maybe I'll write one
> > when I have some leisure...)>
> >> If
> >> you want to stop changes for a while, disable record processing
> >> using
> >> SDIS & DISV.
> > I don't think this will prevent the VAL from changing e.g. due to
> > put
> > operations, or does it?
> >>> This is from the
> >>> RRM
> >>> (https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Outp
> >>> u
> >>> t#Desired_Output_Parameters):
> >>> The VAL field's value is forced to be within the limits specified
> >>> in
> >>> the fields DRVH and DRVL, which are configured by the designer:
> >>> DRVL<=VAL<=DRVH
> >>> Note: If nothing is entered for DRVH and DRVL, the output value
> >>> will
> >>> never change.
> >> Wiki page fixed to document existing code.
> > Thanks.
> > Ben
> > "Make it so they have to reboot after every typo." ― Scott Adams
> > ________________________________
> > Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> > Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> > Forschungszentren e.V.
> > Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> > stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph Geschäftsführung:
> > Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> > Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> > Postadresse:
> > Hahn-Meitner-Platz 1
> > D-14109 Berlin
> > http://www.helmholtz-berlin.de
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
D-14109 Berlin
EPICS alarming on VAL != X Jameson Graef Rollins
Re: EPICS alarming on VAL != X Benjamin Franksen
Re: EPICS alarming on VAL != X Dirk Zimoch
Prev: Re: EPICS alarming on VAL != X Dirk Zimoch
Next: Re: EPICS alarming on VAL != X Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
