1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS alarming on VAL != X
To: [email protected]
Date: Fri, 25 Jul 2014 14:34:13 +0200
Does it make sense to change the code to:
if (prec->drvh >= prec->drvl)
And change the default values so that DRVL>DRVH (e.g. DRVL=0, DRVH=-1)
Then nothing would change if the db designer ignores the fields.
Another alternative is to set default values DRVL=-Inf and DRVH=Inf.
Dirk
On 25.07.2014 14:05, Benjamin Franksen wrote:
On Thursday 24 July 2014 11:27:24 Andrew Johnson wrote:
On 07/24/2014 04:47 AM, Benjamin Franksen wrote:
On Thursday 24 July 2014 11:15:56 Dirk Zimoch wrote:
On 21.07.2014 12:41, Benjamin Franksen wrote:
Why don't you just set DRVL=DRVH=<the desired value>.
      /* check drive limits */
      if (prec->drvh > prec->drvl) {
          if (value > prec->drvh)
              value = prec->drvh;
          else if (value < prec->drvl)
              value = prec->drvl;
DRVL=DRVH => no check at all!
Strange. Not intuitive to me. And contrary to the docs.
That check predates the CVS history of the aoRecord.c file (1995). It
makes perfect sense to me, there has to be a way to disable the
clipping behaviour,
Hm, yes, that makes sense.
and the assumption is that you would only create
ao records for things that you want to be able to actually change.
In general, yes, but there are exceptions. I have used ao or ai records
to hold physical constants as parameters for a calculation. It would be
nice if I could tell the database to fix the value and not even allow a
db or ca put to change them. (One solution could be a simple record type
for such parameters. Maybe I'll write one when I have some leisure...)
If
you want to stop changes for a while, disable record processing using
SDIS & DISV.
I don't think this will prevent the VAL from changing e.g. due to put
operations, or does it?
This is from the
RRM
(https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Outpu
t#Desired_Output_Parameters):
The VAL field's value is forced to be within the limits specified in
the fields DRVH and DRVL, which are configured by the designer:
DRVL<=VAL<=DRVH
Note: If nothing is entered for DRVH and DRVL, the output value will
never change.
Wiki page fixed to document existing code.
Thanks.
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: EPICS alarming on VAL != X Benjamin Franksen
EPICS alarming on VAL != X Jameson Graef Rollins
Re: EPICS alarming on VAL != X Andrew Johnson
Prev: Re: EPICS alarming on VAL != X Benjamin Franksen
Next: Re: EPICS alarming on VAL != X Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
