1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: can't see epicsqt widgets in QT designer
To: <[email protected]>
Date: Sat, 26 Jul 2014 12:06:10 -0700
This is what I do:
I create a link to the epicsqt plug ins library in the qt/plugins/designer directory like so:
ln -s $epicsqt_root/framework/designer/libQEPlugins.so <qt root path>/plugins/designer/libQEPlugins.so
Hope that helps.
Zen
On 07/25/14 19:05, Hansen wrote:
QE framework already compile successfully and can see QWT widgets in QT designer. The QT_PLUGIN_PATH set to "/$epicsqt_root/framework" but still can't see any epicsqt widgets in QT designer.
Anybody can help me to analyse what is the reason?
can't see epicsqt widgets in QT designer Hansen
Prev: can't see epicsqt widgets in QT designer Hansen
Next: RE: can't see epicsqt widgets in QT designer Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
