1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: can't see epicsqt widgets in QT designer
To: Hansen <[email protected]>, tech-talk <[email protected]>
Date: Sun, 27 Jul 2014 09:17:56 +0000
Hi Hansen
In Designer you can have a look in 'Help->About Plugins'. If Designer has found the plugin library, but is not happy loading it it will usually list the plugin in the list and note what problem it had with it. For example, under windows it may state that it can't use a plugin built in debug with others built in release mode mode.
What you have done - set QT_PLUGIN_PATH is a simple and very robust way to point to plugin libraries, (but it does need to point to the 'designer' directory containing the plugin - which you appear to do correctly).
There are however other ways for Designer to locate you plugin library, such as copy the plugin library to same directory as Designer's other plugins.
http://qt-project.org/doc/qt-5/deployment-plugins.html i think contains the definitive rules Designer uses for locating plugins.
http://canvoki.net/Codders/qtpluginnotloading.html lists quite a few reasons why plugins don't load, which may also help.
Are you sure the QT_PLUGIN_PATH environment variable is defined when Designer runs?
Can you launch Designer from the same environment for which you can run the following command?
$ ls $QT_PLUGIN_PATH/designer
libQEPlugin.so
Regards
Andrew
From: [email protected] [[email protected]] on behalf of Hansen [[email protected]]
Sent: Saturday, 26 July 2014 12:05
To: tech-talk
Subject: can't see epicsqt widgets in QT designer
QE framework already compile successfully and can see QWT widgets in QT designer.
The QT_PLUGIN_PATH set to "/$epicsqt_root/framework" but still can't see any epicsqt widgets in QT designer.
Anybody can help me to analyse what is the reason?
can't see epicsqt widgets in QT designer Hansen
Prev: Re: can't see epicsqt widgets in QT designer Zenon Szalata
Next: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
