Ned, I'll look into that method as well - thanks!
-Mark
-----Original Message-----
Sent: Monday, July 28, 2014 2:46 PM
To: Poff, Mark A; Johnson, Andrew N.; [email protected]
Subject: RE: Subroutine invoked only when PV limit exceeded?
If you don't mind adding another record, a calcout record could do the condition testing on SEVR and then process the subroutine record when needed. It has options like "When Zero", "Transition to Zero", "Transition to non-zero", etc. This keeps the logic in the database ... if you prefer ...
Ned
From: [email protected] [[email protected]] on behalf of Poff, Mark A [[email protected]]
Sent: Monday, July 28, 2014 01:35 PM
To: Johnson, Andrew N.; [email protected]
Cc: Poff, Mark A
Thanks, Andrew, I'll try that.
-Mark
Sent: Monday, July 28, 2014 2:26 PM
To: Poff, Mark A; [email protected]
Subject: Re: Subroutine invoked only when PV limit exceeded?
Hi Mark,
On 07/28/2014 01:01 PM, Poff, Mark A wrote:
> Andrew, thanks very much for that suggestion. I modified the sub
> record as follows and it seems to work:
> record("MY_PV_sub")
> field(SDIS, "MY_PV.SEVR")
> field(DISV, "0")
> field(INPA, "MY_PV")
> field(SNAM, "MY_PV_subroutine")
> This prevents the subroutine from being called when the Severity is
> zero
> - which is a significant improvement - but if the PV value bounces
> around while in the HIHI range (for example), the subroutine is called
> each time. What I was hoping for is a setup which calls the
> subroutine only once when an alarm state is entered, and isn't called
> again until the alarm state is exited/re-entered. For example,
> perhaps the subroutine, when called, could examine the current
> severity level and change the DISV value on the fly to a different
> severity level...but that might be a pretty ugly way to do it. Do you have any thoughts?
You should look at the HYST field of the longin record, which was added to prevent alarm chattering (it specifies a dead-band that the value must exceed before the record will exit back out of the current alarm level). Then try removing the foward link from MY_PV and make the SDIS link in MY_PV_sub a CP link, so it will process the MY_PV_sub record only when a monitor event occurs because the value of MY_PV.SEVR has changed.
I think a combination of those two should get you what you want.
- Andrew
Advertising may be described as the science of arresting the human intelligence long enough to get money from it. -- Stephen Leacock
- Subroutine invoked only when PV limit exceeded? Poff, Mark A
- Re: Subroutine invoked only when PV limit exceeded? Andrew Johnson
- RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
- RE: Subroutine invoked only when PV limit exceeded? Arnold, Ned D.
epicsqt on arm board Hansen
<2014>
2025
2026
Installing Pydev plugin for Control System Studio Derek Foster
<2014>
2025
2026
