1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on VxWorks6.9
To: "Mark Rivers" <[email protected]>
Cc: "'Bhavna Merh'" <[email protected]>, "[email protected]" <[email protected]>, "'Eric Norum'" <[email protected]>
Date: Sun, 3 Aug 2014 10:37:08 +0530
Hi Mark,
Initially we would like to just put/port/load the EPICS core  on Vxworks
running on Target Board - MVME-5500 with PowerPC 7447 processor. The we
would like run a  simple IOC with few records. Later on we will proceed to
read the I/O cards etc. Yes, we use synapps and asyn, but on linux based
PC right now for some other application.
Any suggestions will be of great help.
Rgds,
Bhavna
> Hi Amit,
> What is your application for EPICS?
> You might be interested in knowing about the EPICS "synApps" package.  It
> provides drivers for many devices like motors, counters, etc. plus
> additional useful records.
> http://www.aps.anl.gov/bcda/synApps/
> synApps uses some other useful modules like asyn:
> http://www.aps.anl.gov/epics/modules/soft/asyn/
> and StreamDevice
> http://epics.web.psi.ch/software/streamdevice/doc/
> Mark
> -----Original Message-----
> From: Amit Chauhan [mailto:[email protected]]
> Sent: Friday, August 01, 2014 8:11 AM
> To: Mark Rivers; 'Dirk Zimoch'; 'Eric Norum'
> Cc: 'Bhavna Merh'; [email protected]
> Hi,
> I made a couple of changes in the 'stdio.h' file in WindRiver
> installation.
> After that the make process completed successfully without any errors.
> Thus it seems that EPICS base has got compiled for VxWorks 6.9
> Now we seek suggestions as to how to proceed further from this point as in
> integrating EPICS with VxWorks Image and building applications that makes
> use of EPICS features.
> Thanks & Regards,
> Amit.
> From: Mark Rivers [mailto:[email protected]]
> Sent: Wednesday, July 30, 2014 6:28 PM
> To: Amit Chauhan; 'Dirk Zimoch'; 'Eric Norum'
> Hi Amit,
> I am confused.  In your previous post the error message was:
> But now the make process is stopping with following errors related to a
> file
> named 'epicsSingleton.h' :
> base-3-14-12-4\\include
> ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp
> epicsOnce.cpp
> ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(37) : error C2039:
> 'size_t' : is not a member of 'std'
> ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(82) : error C2955:
> 'epicsSingleton' : use of class template requires template argument list
>         ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(78) : see
> declaration of 'epicsSingleton'%0
Prev: mrfioc2 release 2.0.3 Michael Davidsaver
Next: RE: 回复: RE: 回复:epicsqt on arm board Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS on VxWorks6.9 Mark Rivers
Next: CSS is frozen after starts an external program Chen Xue
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
