1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 回复: RE: 回复:epicsqt on arm board
To: Hansen <[email protected]>, Emmanuel Mayssat <[email protected]>, tech-talk <[email protected]>
Date: Mon, 4 Aug 2014 00:13:34 +0000
Hi Hansen
I’d love to hear  more details on the arm environment you are using. Also, I’d be happy to add arm build information into the epicsqt documentation.
Regards
Andrew
Sent: Friday, 1 August 2014 7:11 PM
To: Emmanuel Mayssat; tech-talk
Cc: Andrew Rhyder
Subject:
复: RE: 复:epicsqt on arm board
Hi all,
Finally, I find what's the problem, because the localhost(127.0.0.1) is not up. now it works well!
so I appreciate all your help.
Thank you very much.
------------------ Ô­Ê¼Óʼþ ------------------
·¢¼þÈË: "Emmanuel Mayssat";<[email protected]>;
·¢ËÍʱ¼ä: 2014Äê8ÔÂ1ÈÕ(ÐÇÆÚÎå) ÖÐÎç1:28
ÊÕ¼þÈË: "Hansen"<[email protected]>; "EPICS mailing list"<[email protected]>;
³­ËÍ: "Andrew Rhyder"<[email protected]>;
Ö÷Ìâ:  RE: »Ø¸´£ºepicsqt on arm board
Hansen,
We need more information:
Which board are you using?
What OS?
Did you cross compile with Qt creator?
If so which toolchain and which version of Qt are you using?
The problem you have seem to be coming from your network configuration though or your EPICS environment.
How many  network interfaces to you have?
What about your EPICS environment (env | grep EPICS )?
Emmanuel
To: [email protected]; [email protected]
Subject: »Ø¸´£ºepicsqt on arm board
Date: Fri, 1 Aug 2014 10:47:40 +0800
Hi all,
I think it's the problem that run caclient and IOC on the same board, any document introduce how to implement it?
when I run epicsqt app , always got such message:
error sending registration message to CA repeater daemon was "Network is unreachable"
Thank you if anybody can give me some help, I will appreciate it.
------------------ ԭʼÓʼþ ------------------
·¢¼þÈË: "ÎÒ×Ô¼ºµÄÓÊÏä";<[email protected]>;
·¢ËÍʱ¼ä: 2014Äê7ÔÂ31ÈÕ(ÐÇÆÚËÄ) ÍíÉÏ9:03
ÊÕ¼þÈË: "Hansen"<[email protected]>; "tech-talk"<[email protected]>;
Ö÷Ìâ: Re:epicsqt on arm board
Hi all,
I nearly succeed in playing epicsqt on arm board.
when I put  epicsqt app with IOC on the same board, the epicsqt app can't detect the pv change, but when I put the epicsqt app on another arm board, the epicsqt app can automatically detect the pv change.
anybody has idea about it?
------------------ Original ------------------
Date:  Tue, Jul 29, 2014 08:58 PM
To:  "tech-talk"<[email protected]>;
Subject:  epicsqt on arm board
Anybody compile epicsqt on arm using cross compiler?
epicsqt on arm board Hansen
Re:epicsqt on arm board =?gb18030?b?SGFuc2Vu?=
=?gb18030?b?u9i4tKO6ZXBpY3NxdCBvbiBhcm0gYm9hcmQ=?= =?gb18030?b?SGFuc2Vu?=
RE: 回复:epicsqt on arm board Emmanuel Mayssat
=?gb18030?b?u9i4tKO6IFJFOiC72Li0o7plcGljc3F0IG9uIGFy?==?gb18030?b?bSBib2FyZA==?= =?gb18030?b?SGFuc2Vu?=
Prev: RE: EPICS on VxWorks6.9 "भावना न���तिन मेढ़"
Next: Re: Recommended Control HWs for High Voltage Platform Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: =?gb18030?b?u9i4tKO6IFJFOiC72Li0o7plcGljc3F0IG9uIGFy?==?gb18030?b?bSBib2FyZA==?= =?gb18030?b?SGFuc2Vu?=
Next: Power PMAC and EPICS Time stamps Choon Lim
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
