You need the EPICS extension, msi, version 1-5 or higher in order to
compile synApps. Please see
How to build synApps at the following site:
http://www.aps.anl.gov/bcda/synApps/synApps_5_7.html
The msi extensions is located at
http://www.aps.anl.gov/epics/extensions/msi/index.php
Han
On 08/08/2014 07:33 PM, priya tiwari wrote:
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[4]: Entering directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db/O.linux-x86'
Inflating database from ../vxStats-template.substitutions using local rule
msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null
/bin/sh: msi: command not found
make[4]: *** [../O.Common/vxStats-template.db] Error 127
make[4]: Leaving directory
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp'
make[1]: *** [vxStatsApp.install] Error 2
make[1]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e'
make: ***
[/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e.install] Error 2
srk@localhost:~/epics/synApps/synApps_5_3/support/config$ :Error 127
bash: :Error: command not found...
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
- synApps priya tiwari
Re: Problem linking Mclennan stepper motor libraries into x86 IOC app Andrew Johnson
<2014>
2025
2026
Help with building CSS using cs-studio-3.3.x Xinyu.Wu
<2014>
2025
2026
