1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem linking Mclennan stepper motor libraries into x86 IOC app
To: Peter Linardakis <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Aug 2014 10:04:09 -0500
Hi Peter,
On 08/07/2014 10:00 PM, Peter Linardakis wrote:
> # Add all the support libraries needed by this IOC
> tandem_LIBS += anunuclear djrestore modbus
> tandem_LIBS += asyn std calc seq pv motor softMotor devIocStats stream streamSynApps
> tandem_LIBS += tsdaqctl
> tandem_LIBS += Mclennan                            # ADDITION 2
> The result of a compilation via make is an error while trying to build
> the x86 version, with output:
> /home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):
> In function `motor_init()':
> drvPM304.cc:(.text+0xa1f): undefined reference to `motor_task(thread_args*)'
> /home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x24):
> undefined reference to `motor_send(mess_node*, driver_table*)'
> /home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x28):
> undefined reference to `motor_free(mess_node*, driver_table*)'
> /home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o):(.data.rel+0x34):
> undefined reference to `motor_update_values(motorRecord*)'
> collect2: ld returned 1 exit status
The problem is that you added the McLennan library in the wrong place in
the Makefile; the order of libraries in an xxx_LIBS variable is
important, and in this case you just need to move the "tandem_LIBS +=
Mclennan" line to /above/ the line that mentions motor.
If you had any other motor drivers in the list then it might not have
mattered (depending on whereabouts their libraries were listed) because
they would have already pulled those motor routines into the binary, but
as it is your new module is apparently the only thing that references
those parts of the motor record, so the linker didn't link them into the
output file when it processed the libmotor.a library. Static linking is
normally done in one pass in the order given, so you must list your
libraries in the order most-derived through to least-derived, which is
why the $(EPICS_BASE_IOC_LIBS) libraries must come last.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Problem linking Mclennan stepper motor libraries into x86 IOC app Peter Linardakis
Prev: Re: synApps Jeong Han Lee
Next: RE: Problem linking Mclennan stepper motor libraries into x86 IOC app Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem linking Mclennan stepper motor libraries into x86 IOC app Peter Linardakis
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
