1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to tag soft channels as undefined/disconnected
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 14 Aug 2014 11:32:50 -0700
But as far as I can tell, Kellee should be able to use ai records as the placeholders — and then things should work.
On Aug 14, 2014, at 11:25 AM, Andrew Johnson <[email protected]> wrote:
Oops, my bad, I mis-read the dbCommon.dbd file, UDF /is/ writable, but
writing to the UDF field of an ao record has little effect:
tux% caput anj:ao.UDF 1
Old : anj:ao.UDF                     0
New : anj:ao.UDF                     0
I think what happened is that the record processed as a result of the
put [since UDF is marked pp(TRUE)], and the process routine overrode the
1 that I set the UDF field to with a 0.
I /can/ set UDF to make an ai record go into UDF/INVALID alarm, but that
doesn't work on an ao record, where I have to write NaN to the VAL field
instead (the UDF field acts more like an output for an ao record).
My apologies to Andrew Starritt who was evidently using an ai record,
whereas Kellee and I were both using ao records.
Eric Norum
[email protected]
How to tag soft channels as undefined/disconnected Kellee Summers
RE: How to tag soft channels as undefined/disconnected Lionberger, Carl A.
Re: How to tag soft channels as undefined/disconnected Kellee Summers
RE: How to tag soft channels as undefined/disconnected Andrew C. Starritt
Re: How to tag soft channels as undefined/disconnected Andrew Johnson
Prev: Re: How to tag soft channels as undefined/disconnected Andrew Johnson
Next: Re: How to tag soft channels as undefined/disconnected Kellee Summers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
