Oops, my bad, I mis-read the dbCommon.dbd file, UDF /is/ writable, but
writing to the UDF field of an ao record has little effect:
tux% caput anj:ao.UDF 1
Old : anj:ao.UDF 0
New : anj:ao.UDF 0
I think what happened is that the record processed as a result of the
put [since UDF is marked pp(TRUE)], and the process routine overrode the
1 that I set the UDF field to with a 0.
I /can/ set UDF to make an ai record go into UDF/INVALID alarm, but that
doesn't work on an ao record, where I have to write NaN to the VAL field
instead (the UDF field acts more like an output for an ao record).
My apologies to Andrew Starritt who was evidently using an ai record,
whereas Kellee and I were both using ao records.
- Andrew
On 08/14/2014 11:55 AM, Eric Norum wrote:
> RRM says otherwise:
> Field Summary
> Field Type DCT Initial Access Modify Rec Proc Monitor PP
> STAT GBLCHOICE No UDF_ALARM Yes No Yes
> SEVR GBLCHOICE No INVALID_ALARM Yes No Yes
> NSTA GBLCHOICE No No Alarm Yes No No
> NSEV GBLCHOICE No No Alarm Yes No No
> ACKS GBLCHOICE No No Alarm Yes No
> ACKT GBLCHOICE No Yes Yes No
> UDF UCHAR No 1 Yes Yes No Yes
> On Aug 14, 2014, at 9:35 AM, Andrew Johnson <[email protected]
> <mailto:[email protected]>> wrote:
>> Hi Kellee,
>> The UDF field is not writeable; you're not doing anything wrong, I don't
>> know how Andrew Starritt achieved the effect he talked about.
>> If you want to put an ao record into a UDF alarm state, put a NaN value
>> into its VAL field:
> Eric Norum
> [email protected] <mailto:[email protected]>
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: How to tag soft channels as undefined/disconnected Eric Norum
- How to tag soft channels as undefined/disconnected Kellee Summers
- RE: How to tag soft channels as undefined/disconnected Lionberger, Carl A.
- Re: How to tag soft channels as undefined/disconnected Kellee Summers
- RE: How to tag soft channels as undefined/disconnected Andrew C. Starritt
- Re: How to tag soft channels as undefined/disconnected Andrew Johnson
ePID deadband on output Pearson, Matthew R.
<2014>
2025
2026
<2014>
2025
2026
