1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to tag soft channels as undefined/disconnected
To: Kellee Summers <[email protected]>, Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Aug 2014 00:21:54 +0000
Hi all,
Just for the record, I was using an ai record.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Kellee Summers
Sent: Friday, 15 August 2014 6:04 AM
To: Andrew Johnson; [email protected]
Subject: Re: How to tag soft channels as undefined/disconnected
Thank you Andrew, this may be the simplest solution, and it was easy to
test.  It does do what I was looking for - since we're using just ao
records, this could do it for us.
On 08/14/2014 09:35 AM, Andrew Johnson wrote:
> Hi Kellee,
> The UDF field is not writeable; you're not doing anything wrong, I don't
> know how Andrew Starritt achieved the effect he talked about.
> If you want to put an ao record into a UDF alarm state, put a NaN value
> into its VAL field:
> tux% camonitor anj:ao
> anj:ao                     <undefined> 0 UDF INVALID
> anj:ao                     2014-08-14 11:12:36.438390 0
> anj:ao                     2014-08-14 11:12:57.543911 nan UDF INVALID
> anj:ao                     2014-08-14 11:13:33.298560 10
> anj:ao                     2014-08-14 11:13:39.533800 nan UDF INVALID
> anj:ao                     2014-08-14 11:13:44.165902 1
> I triggered the above monitors like this:
> tux% caput anj:ao 0
> Old : anj:ao                         0
> New : anj:ao                         0
> tux% caput anj:ao NaN
> Old : anj:ao                         0
> New : anj:ao                         nan
> tux% caput anj:ao 10
> Old : anj:ao                         nan
> New : anj:ao                         10
> Old : anj:ao                         10
> New : anj:ao                         nan
> tux% caput anj:ao 1
> Old : anj:ao                         nan
> New : anj:ao                         1
> Unfortunately this only seems to work for ao records; I thought it would
> work on on ai records too but when I just tried that it didn't actually
> change the record's alarm state. You can't use this approach for most of
> the other record types either since their VAL fields don't have any
> equivalent to a NaN value, but ao records may be all you need. Carl
> Lionberger's device support might be the best way to do what you want
> for other types, although I have never seen or tried it myself.
> There are other ways to control the alarm severity of a record, for
> example you can put the severity you want into the SIMS field, set SIMM
> to 1 and write anything to the PROC field (or to the VAL field). This
> will give you an alarm status of SIMM rather than UDF, but most CA
> clients don't pay much attention to the alarm status so that might not
> bother you.
> HTH,
> - (another) Andrew
> On 08/14/2014 10:41 AM, Kellee Summers wrote:
>> Thanks Andrew,
>> I must have something wrong in my record definition or I am doing
>> something incorrectly, because that does not work for me from my C++
>> program.  I cannot even set the UDF to 1 with a caput.
>>      $ caget lbc:side0:dewarTemp.UDF
>>      lbc:side0:dewarTemp.UDF        0
>>      $ caput lbc:side0:dewarTemp.UDF 1
>>      Old : lbc:side0:dewarTemp.UDF        0
>>      New : lbc:side0:dewarTemp.UDF        0
>> Very simple record definition:
>>      record(ao, "lbc:side0:dewarTemp")
>>              field(DESC, "LBC Blue temperature")
>>              field(EGU, "degrees K")
>>              field(HIHI, "215")
>>              field(HIGH, "210")
>>              field(LOW, "165")
>>              field(LOLO, "160")
>>              field(HHSV, "MAJOR")
>>              field(HSV, "MINOR")
>>              field(LSV, "MINOR")
>>              field(LLSV, "MAJOR")
>> ... Kellee
>> On 08/13/2014 05:45 PM, Andrew C. Starritt wrote:
>>> Hi Kellee,
>>>     I did something like what you are doing. The PV values are written to by a bash script.
>>> If/when the source data did not exist or was stale I did I wrote 1 to the record's UDF field
>>> which set it invalid.
>>>        # Set undefined.
>>>        caput ${pvname:?}.UDF  1
>>> where worked for me, i.e. set SEVR to INVALID and STAT to UDF (using base-3.14.12.3)
>>> Regards
>>> Sent: Thursday, 14 August 2014 12:50 AM
>>> To: Lionberger, Carl A.; [email protected]
>>> This sounds pretty simple and what I'm trying to do.  The problem is I
>>> don't know how to do this part:  "sets the PV invalid"
>>> How do you do that?  Is that just some kind of timeout on the processing?
>>> Thanks for your help,
>>> Kellee
>>> On 08/13/2014 06:47 AM, Lionberger, Carl A. wrote:
>>>> For a project where I had a python program updating soft PVs, I wrote a timeout device support to use instead of the soft channel device support.  It times out and sets the PV invalid if a new value was not put to it within the timeout period since the last put. The C++ application just wouldn't put the value to the PV if the instrument data was invalid, and then the PV would go invalid without further action.  When valid data became available, the application would put it to the PV and the PV status would go normal again.
>>>> Carl
>>>> Carl Lionberger
>>>> Instrument Data Acquisition and Controls
>>>> Spallation Neutron Source
>>>> ________________________________________
>>>> From: [email protected] <[email protected]> on behalf of Kellee Summers <[email protected]>
>>>> Sent: Tuesday, August 12, 2014 7:02 PM
>>>> To: [email protected]
>>>> Subject: How to tag soft channels as undefined/disconnected
>>>> Hi All,
>>>> We have set up an EPICS R3.14.12.4 database of pure software channels
>>>> (on a Linux system) so that we can use the alarm handler. The channel
>>>> values are being driven by a C++ software application that reads our
>>>> instrument data.   When the instrument data is stale (determined by an
>>>> out-of-date timestamp), I would like to
>>>> set the channels to UDF so that the alarm state is INVALID.
>>>> The SEVR and STAT alarm fields are non-modifiable.  I tried setting the
>>>> UDF field but it didn't give me a disconnected channel.
>>>> Do I need to modify the record processing?
>>>> Suggestions?
>>>> Thanks
How to tag soft channels as undefined/disconnected Kellee Summers
RE: How to tag soft channels as undefined/disconnected Lionberger, Carl A.
Re: How to tag soft channels as undefined/disconnected Kellee Summers
RE: How to tag soft channels as undefined/disconnected Andrew C. Starritt
Re: How to tag soft channels as undefined/disconnected Andrew Johnson
Prev: Re: Building Cexp & GeSys with RTEMS 4.10.2 Michael Davidsaver
Next: New users - Channel Access Clients issues Bertrand de Boisdeffre
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to tag soft channels as undefined/disconnected Kellee Summers
Next: Building Cexp & GeSys with RTEMS 4.10.2 Philip Taylor
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
