1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: New users - Channel Access Clients issues
To: Bertrand de Boisdeffre <[email protected]>, "[email protected]" <[email protected]>
Cc: "'Vlad Andrei Rusu'" <[email protected]>
Date: Tue, 19 Aug 2014 13:14:07 +0000
Hi Bertrand,
This sounds like it could be a firewall problem.  Is the iptables firewall running on your system?  If so, see if turning it off fixes the problem:
sudo /etc/init.d/iptables stop
If that is the problem and if you want to run the firewall then you will need to create rules to allow Channel Access through the firewall.
From: [email protected] [[email protected]] on behalf of Bertrand de Boisdeffre [[email protected]]
Sent: Tuesday, August 19, 2014 8:07 AM
To: [email protected]
Cc: 'Vlad Andrei Rusu'
Subject: New users - Channel Access Clients issues
Dear EPICS users,
We installed Epics base 3.14.12.3 on a computer using Scientific Linux.
Then we managed to create, build and run the IOC example application included with the EPICS base.
Now, we would like to create one CAClient to access the PV.
Then we configured the /etc/profile file and added the necessary lines:
EPICS_HOST_ARCH="linux-x86_64"
export EPICS_HOST_ARCH
EPICS_BASE=/opt/epics/base-3.14.12.3
export EPICS_BASE
PATH=$PATH:/opt/epics/base-3.14.12.3/bin/linux-x86_64
EPICS_CA_AUTO_ADDR_LIST=YES (tried this too, but it did not work)
export EPICS_CA_AUTO_ADDR_LIST
EPICS_CA_ADDR_LIST="192.168.163.97 192.168.163.255"
export EPICS_CA_ADDR_LIST
and we am unable to reach any PV in the example app included in Epics.
We am running the example app by running st.cmd in terminal, we can see the PVs inside Iocshell but when I try to connect the PV to a graphical text monitor in MEDM, the Graphical Object is not connected to the PV inside the IOC.
PV Info inside MEDM says:
TYPE: TYPENOTCONN
HOST: <disconnected>
The PV name is correct, we think: rootHost:ai1.VAL and tried rootHost:aiExample1.VAL and they are not receiving any values from the IOC.
When we try to run caExample we get the following errors:
[root@Epics O.linux-x86_64]# ./caExample rootHost:ai1.VAL
CA.Client.Exception...............................................
    Warning: "User specified timeout on IO operation expired"
    Context: "ca_pend_io failure"
    Source File: ../caExample.c line 20
    Current Time: Tue Aug 19 2014 14:54:46.378283619
    Warning: "Virtual circuit disconnect"
    Context: "ca_get failure"
    Source File: ../caExample.c line 21
    Current Time: Tue Aug 19 2014 14:54:46.378688325
    Source File: ../caExample.c line 22
    Current Time: Tue Aug 19 2014 14:54:51.378812388
rootHost:ai1.VAL 0.000000
We thank you in advance for your support.
Best regards,
Bertrand DE BOISDEFFRE & Vlad RUSU
ELI-NP, Horia Hulubei National Institute for Physics and Nuclear Engineering
30 Reactorului Street,
077125 Magurele, Romania
+4021 404 50 89 / 021 404 50 89
www.eli-np.ro<http://www.eli-np.ro/>
Re: New users - Channel Access Clients issues Vlad Andrei Rusu
New users - Channel Access Clients issues Bertrand de Boisdeffre
Prev: New users - Channel Access Clients issues Bertrand de Boisdeffre
Next: Re: New users - Channel Access Clients issues Vlad Andrei Rusu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
