1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error Installing Epics Base on Mac OSX 10.9 (Mavericks)
Date: Thu, 21 Aug 2014 19:27:30 -0700
Hello,
I am trying to set up Epics Base and have followed the README.darwin document.  For step 1, I placed it in my .bash_profile ( extensions/ does not exist in my base-3.14.12/ directory ). I tried placing that script in my .bash_login, but I am not seeing much of a difference.
I have uncommented the relevant line in CONFIG_SITE.Common.darwin-x86 (ARCH_CLASS=x86_64) and defined
EPICS_HOST_ARCH =   linux-x86_64
I am having trouble running 'make.'  Here is my error:
stevens-imac:base-3.14.12 steven$ make
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Nothing to be done for `install'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./tools install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Nothing to be done for `install'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./makeBaseApp install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./makeBaseExt install
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./libCom install
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -g -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include        ../../../src/libCom/env/envSubr.c
../../../src/libCom/env/envSubr.c:398:21: error: use of undeclared identifier      'IPPORT_USERRESERVED'
    if (epicsParam<=IPPORT_USERRESERVED || epicsParam>USHRT_MAX) {
1 error generated.
make[3]: *** [envSubr.o] Error 1
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
I peeked at the source code with the error, and  'IPPORT_USERRESERVED' is used only once in that .c code.  I don't think modifying the *.c file is the solution.  Any ideas?
Steven Wu
Re: Error Installing Epics Base on Mac OSX 10.9 (Mavericks) Torsten Bögershausen
Prev: Re: New users - Channel Access Clients issues Dirk Zimoch
Next: Fall 2014 EPICS Collaboration meeting accomodation Gougnaud Françoise
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Modbus R2-7 available Mark Rivers
Next: Re: Error Installing Epics Base on Mac OSX 10.9 (Mavericks) Torsten Bögershausen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
