Here are some trace I've just collected: IOC boot:------------- #!../../bin/linux-x86_64/streamTest ## You may have to change streamTest to something else ## everywhere it appears in this file < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocstreamTest") epicsEnvSet("TOP","/home/davidmichel/Project/experimental/device/driver") epicsEnvSet("EPICS_BASE","/usr/local/epics/base-3.14.12.3") epicsEnvSet("STREAMDEVICE","/usr/local/epics/support/stream/current") epicsEnvSet("ASYN","/usr/local/epics/support/asyn/current") cd /home/davidmichel/Project/experimental/device/driver ## Register all support components dbLoadDatabase "dbd/streamTest.dbd" streamTest_registerRecordDeviceDriver pdbbase ## Register NewFocus 8742 pico motor controller epicsEnvSet("STREAM_PROTOCOL_PATH","/home/davidmichel/Project/experimental/device/driver/protocols") drvAsynIPPortConfigure("MC1","192.168.42.240:23") ## debug tracing asynSetTraceIOMask("MC1",0,0xFF) asynSetTraceMask("MC1",0,0xFF) ## Load record instances dbLoadRecords("db/device_driver.db","DEVICE=MC1") dbLoadRecords("db/axis.db","DEVICE=MC1, AXIS=1") cd /home/davidmichel/Project/experimental/device/driver/iocBoot/iocstreamTest iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$ ## EPICS Base built Aug 8 2013 ############################################################################ 2014/09/05 14:14:45.181 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.181 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.181 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.181 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.181 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.181 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.181 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.182 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.182 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.182 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.182 192.168.42.240:23 read. 2014/09/05 14:14:45.182 192.168.42.240:23 read 6 ���� \377\375\003\377\373\001 ff fd 03 ff fb 01 2014/09/05 14:14:45.182 MC1 read ���� \377\375\003\377\373\001cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 44650, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) ff fd 03 ff fb 01 2014/09/05 14:14:45.182 192.168.42.240:23 read. iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=davidmichelHost" 2014/09/05 14:14:45.183 MC1 get Eos 0 2014/09/05 14:14:45.183 MC1 set Eos 0 2014/09/05 14:14:45.183 192.168.42.240:23 write. 2014/09/05 14:14:45.183 192.168.42.240:23 write 5 1AC? 1AC?\r 31 41 43 3f 0d 2014/09/05 14:14:45.183 wrote 5 to 192.168.42.240:23, return asynSuccess. 2014/09/05 14:14:45.183 MC1 wrote 1AC? 1AC?\r 31 41 43 3f 0d 2014/09/05 14:14:45.183 MC1 set Eos 0 2014/09/05 14:14:45.183 MC1 addr -1 queueRequest priority 0 from lockHolder 2014/09/05 14:14:45.183 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.183 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.183 MC1 get Eos 0 2014/09/05 14:14:45.183 MC1 set Eos 2 \r\n 0d 0a 2014/09/05 14:14:45.183 192.168.42.240:23 read. 2014/09/05 14:14:45.184 192.168.42.240:23 read 8 100000 100000\r\n 31 30 30 30 30 30 0d 0a 2014/09/05 14:14:45.184 MC1 read 100000 100000\r\n 31 30 30 30 30 30 0d 0a 2014/09/05 14:14:45.184 MC1 set Eos 0 2014/09/05 14:14:45.184 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.184 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.184 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.184 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.184 192.168.42.240:23 read. 2014/09/05 14:14:45.185 MC1 get Eos 0 2014/09/05 14:14:45.185 MC1 set Eos 0 2014/09/05 14:14:45.185 192.168.42.240:23 write. 2014/09/05 14:14:45.185 192.168.42.240:23 write 5 1VA? 1VA?\r 31 56 41 3f 0d 2014/09/05 14:14:45.185 wrote 5 to 192.168.42.240:23, return asynSuccess. 2014/09/05 14:14:45.185 MC1 wrote 1VA? 1VA?\r 31 56 41 3f 0d 2014/09/05 14:14:45.185 MC1 set Eos 0 2014/09/05 14:14:45.185 MC1 addr -1 queueRequest priority 0 from lockHolder 2014/09/05 14:14:45.185 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.185 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.185 MC1 get Eos 0 2014/09/05 14:14:45.185 MC1 set Eos 2 \r\n 0d 0a 2014/09/05 14:14:45.185 192.168.42.240:23 read. 2014/09/05 14:14:45.186 192.168.42.240:23 read 6 2000 2000\r\n 32 30 30 30 0d 0a 2014/09/05 14:14:45.186 MC1 read 2000 2000\r\n 32 30 30 30 0d 0a 2014/09/05 14:14:45.186 MC1 set Eos 0 2014/09/05 14:14:45.186 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.186 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 14:14:45.186 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.186 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.186 192.168.42.240:23 read. 2014/09/05 14:14:45.187 MC1 get Eos 0 2014/09/05 14:14:45.187 MC1 set Eos 0 2014/09/05 14:14:45.187 192.168.42.240:23 write. 2014/09/05 14:14:45.188 192.168.42.240:23 write 8 IPADDR? IPADDR?\r 49 50 41 44 44 52 3f 0d 2014/09/05 14:14:45.188 wrote 8 to 192.168.42.240:23, return asynSuccess. 2014/09/05 14:14:45.188 MC1 wrote IPADDR? IPADDR?\r 49 50 41 44 44 52 3f 0d 2014/09/05 14:14:45.188 MC1 set Eos 0 2014/09/05 14:14:45.188 MC1 addr -1 queueRequest priority 0 from lockHolder 2014/09/05 14:14:45.188 MC1 schedule queueRequest timeout 2014/09/05 14:14:45.188 asynManager::portThread port=MC1 callback 2014/09/05 14:14:45.188 MC1 get Eos 0 2014/09/05 14:14:45.188 MC1 set Eos 2 \r\n 0d 0a 2014/09/05 14:14:45.188 192.168.42.240:23 read. 2014/09/05 14:14:45.188 192.168.42.240:23 read 16 192.168.42.240 192.168.42.240\r\n 31 39 32 2e 31 36 38 2e 34 32 2e 32 34 30 0d 0a 2014/09/05 14:14:45.189 MC1 read 192.168.42.240 192.168.42.240\r\n 31 39 32 2e 31 36 38 2e 34 32 2e 32 34 30 0d 0a 2014/09/05 14:14:45.189 MC1 set Eos 0 epics> IOC shell output when error occurs -------------------------------------------------- 2014/09/05 15:17:51.953 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 15:17:51.953 MC1 schedule queueRequest timeout 2014/09/05 15:17:51.953 asynManager::portThread port=MC1 callback 2014/09/05 15:17:51.953 MC1 addr -1 queueRequest priority 0 not lockHolder 2014/09/05 15:17:51.953 MC1 schedule queueRequest timeout 2014/09/05 15:17:51.953 asynManager::portThread port=MC1 callback 2014/09/05 15:17:51.953 192.168.42.240:23 read. 2014/09/05 15:17:51.954 MC1 get Eos 0 2014/09/05 15:17:51.954 MC1 set Eos 0 2014/09/05 15:17:51.954 192.168.42.240:23 write. 2014/09/05 15:17:51.954 192.168.42.240:23 write 5 1MD? 1MD?\r 31 4d 44 3f 0d 2014/09/05 15:17:51.954 wrote 5 to 192.168.42.240:23, return asynSuccess. 2014/09/05 15:17:51.954 MC1 wrote 1MD? 1MD?\r 31 4d 44 3f 0d 2014/09/05 15:17:51.954 MC1 set Eos 0 2014/09/05 15:17:51.954 MC1 addr -1 queueRequest priority 0 from lockHolder 2014/09/05 15:17:51.954 MC1 schedule queueRequest timeout 2014/09/05 15:17:51.954 asynManager::portThread port=MC1 callback 2014/09/05 15:17:51.954 MC1 get Eos 0 2014/09/05 15:17:51.954 MC1 set Eos 2 \r\n 0d 0a 2014/09/05 15:17:51.954 192.168.42.240:23 read. 2014/09/05 15:17:51.954712 MC1 MC1:A1_DONE: No reply from device within 1000 ms 2014/09/05 15:17:51.955 MC1 set Eos 0 ------------------------------------------------------------------------- MC1 multiDevice:No canBlock:Yes autoConnect:Yes enabled:Yes connected:Yes numberConnects 1 nDevices 0 nQueued 0 blocked:No asynManagerLock:No synchronousLock:Yes exceptionActive:No exceptionUsers 1 exceptionNotifys 0 interposeInterfaceList asynOctet pinterface 0x7f8e7d51d400 drvPvt 0x1e1f9d0 interfaceList asynCommon pinterface 0x7f8e7d51a8c0 drvPvt 0x1d9abe0 asynOctet pinterface 0x1d9acc8 drvPvt 0x1d9abe0 Port 192.168.42.240:23: Connected fd: 4 Characters written: 49373 Characters read: 28848 --- Dr. David Michel Address: 8 Viking Drive, Didcot, OX11 9RD, Oxfordshire Mobile: 0789 670 98 01 - Home: 0123 581 46 93 On 5 September 2014 14:33, David Michel <[email protected]> wrote:
| ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
