1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Modbus TCP/IP "PSH" Command
To: "'Tobin Weber'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 Sep 2014 17:16:45 +0000
Hi Tobin,
Can you please send the output of the following command at the IOC prompt:
dbpr(“AcroRead”,10)
That will show us the content of all the fields of the asyn record.
If the only settings of the fields in that record comes from the asynRecord.dbd file and the PortCheck.vdb file you sent, then it should be sending the contents of the AOUT field and reading back into the AINP field.  The AOUT field should be an empty string unless it has somehow been set otherwise.
But the asyn record is talking to the port through the modbusInterposeInterface.  This is the code from the write function in the modbusInterpose driver for TCP links:
/* asynOctet methods */
static asynStatus writeIt(void *ppvt, asynUser *pasynUser,
                          const char *data, size_t numchars,
                          size_t *nbytesTransfered)
    modbusPvt  *pPvt = (modbusPvt *)ppvt;
    asynStatus status = asynSuccess;
    size_t     nbytesActual = 0;
    size_t     nWrite;
    modbusMBAPHeader mbapHeader;
    unsigned short transactId=1;
    unsigned short cmdLength = numchars;
    unsigned short modbusEncoding=0;
    int mbapSize = sizeof(modbusMBAPHeader);
    unsigned char CRC_Hi;
    unsigned char CRC_Lo;
    unsigned char LRC;
    char *pout;
    int i;
    if (pPvt->writeDelay > 0.0) epicsThreadSleep(pPvt->writeDelay);
    pasynUser->timeout = pPvt->timeout;
    switch(pPvt->linkType) {
        case modbusLinkTCP:
            /* Build the MBAP header */
            mbapHeader.transactId    = htons(transactId);
            mbapHeader.protocolType  = htons(modbusEncoding);
            mbapHeader.cmdLength     = htons(cmdLength);
            /* Copy the MBAP header to the local buffer */
            memcpy(pPvt->buffer, &mbapHeader, mbapSize);
            /* Copy the Modbus data to the local buffer */
            memcpy(pPvt->buffer + mbapSize, data, numchars);
            /* Send the frame with the underlying driver */
            nWrite = numchars + mbapSize;
            status = pPvt->pasynOctet->write(pPvt->octetPvt, pasynUser,
                                             pPvt->buffer, nWrite,
                                             &nbytesActual);
            *nbytesTransfered = (nbytesActual > numchars) ? numchars : nbytesActual;
            break;
So the modbusInterpose layer is adding some additional bytes to the start of the message (the mbapHeader).  I suspect those are what you are seeing as “PSH”.
You should not need to use Wireshark to diagnose this if indeed the string is coming from the IOC.  You should just be able to do the following in your st.cmd file:
# Set the TRACEIO_ESCAPE and ASYN_TRACEIO_HEX bits
asynSetTraceIOMask(“ReadPort,0,6)
# Turn on ASYN_TRACEIO_DRIVER and ASYN_TRACE_ERROR
asynSetTraceMask(“ReadPort”,0,9)
That will show you all of the Modbus I/O as well as the I/O from the asyn record.
I don’t really understand how you expected the asyn record to work.  You have not configured it to send valid Modbus commands, so how is it supposed to do port checking?  It seems that it will send data that is not expected by the device because it won’t contain a valid Modbus command.
From: [email protected] [mailto:[email protected]] On Behalf Of Tobin Weber
Sent: Friday, September 05, 2014 11:12 AM
To: [email protected]
Subject: Modbus TCP/IP "PSH" Command
Hello Colleagues,
We use a type of distributed I/O device that talks Modbus TCP/IP called an Acromag 952EN-4012. We have had re-occurring issues with these devices over the last few years. Most recently, we have experienced the devices losing communication with our EPICS IOC. We believe we have traced the source of this problem down to a Port checking procedure that we were doing. This procedure simply involves processing an asyn record that is linked to the IP Port created for modbus access.
The simplest example of an IOC that produces these errors is created with the following start up file:
drvAsynIPPortConfigure("ReadPort","192.168.0.78:502",0,0,1)
modbusInterposeConfig("ReadPort", 0, 1000,0)
dbLoadRecords("db/PortCheck.vdb")
With PortCheck.vdb being:
record(asyn, AcroRead) {
field(PORT, "ReadPort")
field(TMOD, "Write/Read")
field(SCAN, "1 second")
We usually read the .ERRS and .CNCT fields on AcroRead to check the port, but I left that out of the epics code b/c it doesn't appears to make a difference.
When AcroRead processes, we think the CPU (0.182) sends a "PSH" or Push Command to the Acromag Device (0.78) [See attached wirehshark file Acroamg_Port_Check_Tech_Talk]. After acknowledging this packet, the Acromag device responds with an exception. It appears to not understand the "PSH" command. I've spoken with Acromag Engineers and they said their devices will not know how to process this command.
We are fairly certain that this process, when combined with the reads and writes we do, will intermittently cause the Acromag device to stop responding completely to the EPICS IOC.
My question: Is the "PSH" command being sent expected behavior in this situation? What are the origins of this command?
Thanks very much for any help you can provide.
Toby
Tobin Weber
University of Washington
Fast Neutron Therapy
206-598-0485
Re: Modbus TCP/IP "PSH" Command Tobin Weber
Prev: Modbus TCP/IP "PSH" Command Tobin Weber
Next: RE: Processing a record a in loop Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Modbus TCP/IP "PSH" Command Tobin Weber
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
