1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin
To: "J. Lewis Muir" <[email protected]>, <[email protected]>
Date: Fri, 5 Sep 2014 17:33:24 -0500
On 09/05/2014 05:30 PM, J. Lewis Muir wrote:
> On 9/5/14, 5:06 PM, Andrew Johnson wrote:
>> Running that symbol through c++filt on a Mac gives the following
>> unmangled name:
>> woz$ c++filt __ZNSs4_Rep20_S_empty_rep_storageE
>> std::string::_Rep::_S_empty_rep_storage
>> Doing a web search on that implies that you need to link against
>> libstdc++, so try adding this to the Makefile that builds
>> simDetectorApp:
>>     OP_SYS_LDLIBS += -lstdc++
> Hi, Andrew.
> Thanks for the suggestion.  Unfortunately, no dice; it still aborts.
Did you see the -lstdc++ option on the command-line that generated the
IOC? I may have the wrong Makefile variable if not. If you did, it may
be some other library that needs the flag.
Sorry I don't have time for more ideas tonight, good luck!
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Andrew Johnson
Prev: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Next: -D__STDC_VERSION__=199901L Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
