1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mbboDirect problems
To: "'Eric Norum'" <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Mon, 8 Sep 2014 22:01:44 +0000
I think that is the way the mbboRecord works.  This is from the process() function:
        if(prec->nsev < INVALID_ALARM
        && prec->sevr == INVALID_ALARM
        && prec->omsl == menuOmslsupervisory) {
            /* reload value field with B0 - B15 */
            int offset = 1, i;
            unsigned char *bit = &(prec->b0);
            for (i=0; i<NUM_BITS; i++, offset = offset << 1, bit++) {
                if (*bit)
                    prec->val |= offset;
                else
                    prec->val &= ~offset;
        /* convert val to rval */
        convert(prec);
If I read this correctly then the first time the record processes sevr==INVALID_ALARM so it will overwrite the VAL field with the Bn fields.
Sent: Monday, September 08, 2014 4:44 PM
To: Mark Rivers
Subject: Re: mbboDirect problems
Yes.
On Sep 8, 2014, at 2:41 PM, Mark Rivers <[email protected]> wrote:
Does it work if you write to a bit field?
Sent: Monday, September 08, 2014 4:17 PM
To: Mark Rivers
The VAL field.
On Sep 8, 2014, at 2:11 PM, Mark Rivers <[email protected]> wrote:
What field is the client writing to?  The VAL field or an individual bit?
In R4-21 the following change was made:
“Improved the initMbboDirect function in devAsynUInt32Digital.c. If an initial value is read successfully from the driver it now sets the .Bn fields in the record. It also sets VAL rather than RVAL and returns 2 rather than 0. Thanks to Andrew Johnson for this.”
Sent: Monday, September 08, 2014 3:50 PM
To: EPICS mailing list
Subject: mbboDirect problems
I have a number of mbboDirect records like:
record(mbboDirect, "$(P)$(R)EVR:event12trig") {
    field(DESC, "Extraction pre-trigger")
    field(DTYP, "asynUInt32Digital")
    field(OUT,  "@asynMask($(PORT) 0x30C 0xFF 0)")
    field(NOBT, "8")
    field(MASK, "0xFF")
The IOC starts up and reads back the initial value of this record properly.
The *first* caput to the record (I’ve tried from EDM and from caput) writes the readback value again, not the value from the client.
Subsequent caputs do write the value from the client.  It’s only the first operation that uses old data.
Is this a known problem?
Eric Norum
[email protected]
Eric Norum
[email protected]
Eric Norum
[email protected]
Re: mbboDirect problems Eric Norum
RE: mbboDirect problems Mark Rivers
Prev: Re: mbboDirect problems Eric Norum
Next: Re: mbboDirect problems Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mbboDirect problems Eric Norum
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
