1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: check what is caput doing
To: <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Wed, 10 Sep 2014 10:48:35 +0200
you are looking at different records:
LEBT:LEBT:PS:STH1:OPER:CurrSP
and
Please check.
Dr. Burkhard Kolb
Tel +49 6159 712667
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker,
Dr.-Ing. Jürgen Henschel
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Am 10.09.2014 um 10:30 schrieb [email protected]:
> Dear Ralph,
> Thanks for the comment.
>> The "cainfo" command line tool will tell you if you can connect
>> successfully, and if you have the necessary access rights. (Which you
>> should have if caput does not show errors.)
> The outuput of cainfo is
>    State:            connected
>    Host:             10.30.0.10:5064
>    Access:           read, write
>    Native data type: DBF_DOUBLE
>    Request type:     DBR_DOUBLE
>    Element count:    1
>> Some records have mechanisms (like the DRVH/DRVL drive limits of the ao
>> record or the OMSL mode selection of many output records) that would
>> reject certain values written to the PV. Some fields of some record
>> types cannot be written to at all through Channel Access (see the Record
>> Reference Manual for details on that).
>> What value are you trying to write to which field of what record type?
> THis is the current setpoint of a power suplly.
> The IOC db file contains this information
> record(ai,"LEBT:PS:STH1:OPER:CurrSP"){
>  field(INP,"LV:LEBT:PS:STH1:OPER:CurrSP CP")
>  field(DESC,"PS EXT Voltage")
>  field(DESC, "LEBT STH1 Current SP")
> I guess that I am trying to change the INP field which has no access
> permission according to the Record Reference Manual, isn't it?
> In this case how is possible that the value can be changed with the CSS GUI?
> Should have the record a VAL field?
> Sorry if they are trivial questions; but I new to EPICS.
> Zunbeltz
>> Cheers,
>> ~Ralph
check what is caput doing zunbeltz
Re: check what is caput doing Ralph Lange
Re: check what is caput doing zunbeltz . izaola
Prev: Device Support Options for NI RIO Ralph Lange
Next: Re: check what is caput doing Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: check what is caput doing zunbeltz . izaola
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
