On 10/09/2014 10:30, [email protected] wrote:
The outuput of cainfo is
LEBT:LEBT:PS:STH1:OPER:CurrSP
State: connected
Host: 10.30.0.10:5064
Access: read, write
Native data type: DBF_DOUBLE
Request type: DBR_DOUBLE
Element count: 1
Full access - no firewall and/or access security issue. Good.
What value are you trying to write to which field of what record type?
This is the current setpoint of a power supply.
The IOC db file contains this information
record(ai,"LEBT:PS:STH1:OPER:CurrSP"){
field(INP,"LV:LEBT:PS:STH1:OPER:CurrSP CP")
field(DESC,"PS EXT Voltage")
field(DESC, "LEBT STH1 Current SP")
I guess that I am trying to change the INP field which has no access
permission according to the Record Reference Manual, isn't it?
In this case how is possible that the value can be changed with the CSS GUI?
Should have the record a VAL field?
This input record is configured (through its INP setting) to get its
value from LV:LEBT:PS:STH1:OPER:CurrSP, whenever that record's value
changes.
Writing to the INP field will change the record's configuration to point
to another source for the value.
Writing to the VAL field is probably closer to what you want, but still
- your caput changes the value and processes the record, then during
that processing the record does what it is configured to: it reads the
value from the configured location LV:...:CurrSP.
Bottom line:
If you configure your input record to pull its value from another
location, you cannot change the value by writing to it, and vice versa.
Hint:
Maybe the simulation mode (again: described in the Application
Developers Guide and the Record Reference Manual) is able to achieve
what you want. It allows you to switch your input record into simulation
mode (.SIMM), where it will not use the configured INP link, but a
special simulation link or value (.SIOL) to fetch its value.
Sorry if they are trivial questions; but I new to EPICS.
I would suggest participating at a training. The next public one is held
as part of the EPICS collaboration meeting end of October in Saclay
(Paris), France. There are also people and companies that can provide
in-house training, if that is more appropriate.
Good luck!
~Ralph
- check what is caput doing zunbeltz
- Re: check what is caput doing Ralph Lange
- Re: check what is caput doing zunbeltz . izaola
Re: check what is caput doing Burkhard Kolb
Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
<2014>
2025
2026
Device Support Options for NI RIO Ralph Lange
<2014>
2025
2026
