I have an 32bit Windows 7 operating system installed. I have installed Matlab R2008a and cygwin32 on my PC. I included "PATH" by C:\cygwin\bin". Now I downloaded labca_3_4 and extracted it in F:\LabCA\labca_3_4, then I changed the CONFIG and RELEASE-file in the labca_3_4\configure-folder: CONFIG: I added these lines by Windows Editor - MAKEFOR=MATLAB - CONFIG_USE_CTRLC=YES and RELEASE: - INSTALL_LOCATION_APP= F:/LabCA/labca_3_4 - EPICS_BASE=F:/LabCA/base-3-14-12-4 - MATLABDIR=C:/MATLAB/R2008a - EPICS_HOST_ARCH=cygwin-x86 - MATLIB_SUBDIR=win32/microsoft After this, I opened Cygwin and entered $ cd /cygdrive/f/labca/base-3-14-12-4, entered "make" command. It is ok, no error. And then entered $ cd /cygdrive/f/labca/labca_3_4 and entered command "make", the info like this: $ make make -C ./configure install make[1]: Entering directory '/cygdrive/f/labca/labca_3_4/configure' perl F:/LabCA/base-3.14.12.4/bin/cygwin-x86/makeMakefile.pl O.cygwin-x86 ../.. mkdir O.Common make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install make[2]: Entering directory '/cygdrive/f/labca/labca_3_4/configure/O.cygwin-x86' F:/LabCA/base-3.14.12.4/configure/RULES.Db:198: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:212: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:213: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:199: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:283: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:284: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:213: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:287: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:288: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:284: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:350: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:351: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:288: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:355: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES.Db:356: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:351: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:141: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:142: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES.Db:356: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:145: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:146: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:142: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_JAVA:146: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: target 'F' doesn't match the target pattern F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'F' F:/LabCA/base-3.14.12.4/configure/RULES_BUILD:129: *** target pattern contains no '%'。 停止。 make[2]: Leaving directory '/cygdrive/f/labca/labca_3_4/configure/O.cygwin-x86' F:/LabCA/base-3.14.12.4/configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86' failed make[1]: *** [install.cygwin-x86] Error 2 make[1]: Leaving directory '/cygdrive/f/labca/labca_3_4/configure' F:/LabCA/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'configure.install' failed make: *** [configure.install] Error 2 I can not have solution, so I hope you can give me this answer how to realize the LabCA building. Thank you so much for your support! -- ******************************** 岳 敏 Min Yue Institute of Modern Physics, Chinese Academy of Sciences Tel:+86-0931-4969469 Handy: +86-18509316383 ********************************
| ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
