1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer 2.2.0
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 15 Sep 2014 20:34:06 +0200
Am Montag, 15. September 2014, 16:11:05 schrieb Kasemir, Kay:
> Hi Ben:
> > * all existing built-in functions give compile-time errors when called
> > with an>
> >  array of channels
> > * new functions are introduced in those cases where operating on all
> > contained>
> >  elements of an array makes sense.
> > Please note that all this concerns only arrays where the elements are
> > separately assigned to different channels.
> How would it affect his:
> int channels[3];
> assign channels to { "channel1", "channel2", "channel3" }
> evflag have_changes;
> sync channels have_changes;
> Will this still work, or is this use of 'sync' of one flag to an array of
> channels also affected, so it will result in compile time errors?
Good question!
(which is why I post this to tech-talk, too).
The answer is: Yes, it will still work.
The change I am planning is restricted to built-in functions (those that start
with "pv...", such as "pvSync" which are called at runtime). The "assign",
"monitor", "sync", and "syncq" are keywords that introduce special syntax and
are not affected at all.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Sequencer 2.2.0 Benjamin Franksen
RE: Sequencer 2.2.0 Mooney, Tim M.
Prev: Re: Sequencer 2.2.0 Benjamin Franksen
Next: EPICS vs. Firewalls Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Sequencer 2.2.0 Mooney, Tim M.
Next: Re: Sequencer 2.2.0 Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
