1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stream device protocol files question?
To: "Goff, Steven J" <[email protected]>, EPICS mailing list <[email protected]>
Date: Wed, 17 Sep 2014 12:53:02 -0700
The info you provide is confusing.
If your record is a longin, its value is an integer (not a string, not an error message, ...).
In your protocol, the out line is what the computer writes on the bus to fetch the status of the device.
Base on what I understand, you probably should use a binary out (bo record) for each of your batteries.
You can pass the battery number in the OUT line as a parameter to the protocol
record(bo,  $(prefix):$(number):BatteryOn")
    field(DTYP, ...
    field(out, "mydev.proto getStatus($prefix,$number)) dev)
record(stringin, $(prefix):$(number)Message")
with protocol
getStatus {
  out "Battery On \$2";
  in "OK";
 @mismatch {
      in "%(\$1:\$2Message.VAL)s";               # Write on another PV
The mismatch should not be required if you know all the allowed values for $number.
If that's the case, you just dbLoadRecords with the allowed $number parameters
I hope this helps.
Emmanuel Mayssat
http://www.epicsqt.org
To: [email protected]
Subject: Stream device protocol files question?
Date: Wed, 17 Sep 2014 16:22:11 +0000
Hello,
I am trying to understand how to setup a particular command in a protocol file.
The command looks like this:
Battery On “number”
And the command returns either: “OK” or ”Error: err msg”.
I think my protocol file might look like this:
Battery
 Out “Battery On %d”;
And my db file would look like this:
Record (longin, “batteryOn”)
  Field(DTYP, “stream”)
  Field(INP, “myDev.proto Battery dev”)
How do I get the status that the command returns?
I want to do something like
Battery
  In “%s”;
But I am already using an input for the battery number.  So how do I do both?
Thanks In advance.
Steve Goff
Stream device protocol files question? Goff, Steven J
Prev: Re: Asyn Martin L. Smith
Next: Sequencer web search lists out-dated sites Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Stream device protocol files question? Goff, Steven J
Next: RE: Stream device protocol files question? peter.owens
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
