1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stream device protocol files question?
To: <[email protected]>, <[email protected]>
Date: Thu, 18 Sep 2014 14:48:37 +0000
To start with.
Is that meant to be an output command or an input command?
I was assuming output, but you are using a longin record with an INP field.
IF it is output (ie you are attempting to write the value of the record as the number) Then what you need is an exception handler.
The protocol would look something like:
Battery
    out “Battery On %d”;
    in “OK”;
   @mismatch  { in “Error:%(BatteryError)s”;  }
Where BatteryError is a stringin record.
IF it is an input (ie you are requesting the status from a particular battery) then have one record for each battery and pass the number as a protocol variable:
Record (stringin, “battery-3-On”)
  Field(DTYP, “stream”)
  Field(INP, “myDev.proto Battery(3) dev”)
Battery
    out “Battery On \$1”;
    in “%s”;
Pete
Sent: 17 September 2014 17:22
To: [email protected]
Subject: Stream device protocol files question?
Hello,
I am trying to understand how to setup a particular command in a protocol file.
The command looks like this:
Battery On “number”
And the command returns either: “OK” or ”Error: err msg”.
I think my protocol file might look like this:
Battery
Out “Battery On %d”;
And my db file would look like this:
Record (longin, “batteryOn”)
  Field(INP, “myDev.proto Battery dev”)
How do I get the status that the command returns?
I want to do something like
Battery
  In “%s”;
But I am already using an input for the battery number.  So how do I do both?
Thanks In advance.
Steve Goff
Scanned by iCritical.
Stream device protocol files question? Goff, Steven J
Prev: Re: CSS Basic EPICS help crashing in Ubuntu Kasemir, Kay
Next: Re: Stream device protocol files question? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Stream device protocol files question? Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
