1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream device protocol files question?
To: [email protected]
Date: Fri, 19 Sep 2014 11:42:30 +0200
Hello Steve,
Are you sure that you do not want one record for each battery?
I would expect one bo record to switch one battery on or off:
record (bo, "Battery$(N)OnOff")
  field (DTYP, "stream")
  field (OUT,  "Battery.proto OnOff($(N)) dev”)
OnOff {
 Battery %{On|Off} \$1";
 in "OK";
 @mismatch { in "Error:%(Battery\$1Error)s”; }
(Disadvantage: Last error stays in error record when everything is OK.)
If you have a fixed and known set of error messages, you can also redirect to an mbbi Error record like this:
 in "%(Battery\$1Error){OK|Error: message1|Error: message2}";
Or do you select battery x out of n?
Dirk
On 17.09.2014 18:22, Goff, Steven J wrote:
Hello,
I am trying to understand how to setup a particular command in a
protocol file.
The command looks like this:
Battery On “number”
And the command returns either: “OK” or ”Error: err msg”.
I think my protocol file might look like this:
Battery
  Out “Battery On %d”;
And my db file would look like this:
Record (longin, “batteryOn”)
   Field(DTYP, “stream”)
   Field(INP, “myDev.proto Battery dev”)
How do I get the status that the command returns?
I want to do something like
Battery
   In “%s”;
But I am already using an input for the battery number.  So how do I do
both?
Thanks In advance.
Steve Goff
Stream device protocol files question? Goff, Steven J
Prev: RE: Stream device protocol files question? peter.owens
Next: Re: Asyn Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Sequencer web search lists out-dated sites Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
