1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: snmp error
To: Tech Talk <[email protected]>
Date: Fri, 19 Sep 2014 16:13:25 +0100
I've an error with snmp that I've never seen before and cannot find in tech-talk repositories.
I have some devices which I talk to via snmp.  I have no errors in compilation, nor starting
my (soft) IOC, however they occur for each record which attempts to make the snmp call.
When I use snmp v2c, the error message is:
Record [PVname] parsing response [No Such Instance currently exists at th] error!
When I use snmp v1, the error message is:
Record [PVname] parsing response [ NULL] error!
I'm on an SL6.4 machine and am using V 3.4.12.3
When I do a recursive grep on base, I cannot even find snippets of this error message.
An additional mystery is that the code hasn't changed and used to work when I was
running with SL5.7.
Any ideas?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
Re: snmp error Dirk Zimoch
Prev: Re: EDM Pierrick Hanlet
Next: Re: snmp error John A. Priller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM Michael Westfall
Next: Re: snmp error Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
