1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: snmp error
To: [email protected]
Date: Tue, 23 Sep 2014 11:18:27 +0200
The string "No Such Instance currently exists" can be found in libnetsnmp.so.
Dirk
On 19.09.2014 17:13, Pierrick Hanlet wrote:
I've an error with snmp that I've never seen before and cannot find in
tech-talk repositories.
I have some devices which I talk to via snmp.  I have no errors in
compilation, nor starting
my (soft) IOC, however they occur for each record which attempts to make
the snmp call.
When I use snmp v2c, the error message is:
Record [PVname] parsing response [No Such Instance currently exists at
th] error!
When I use snmp v1, the error message is:
Record [PVname] parsing response [ NULL] error!
I'm on an SL6.4 machine and am using V 3.4.12.3
When I do a recursive grep on base, I cannot even find snippets of this
error message.
An additional mystery is that the code hasn't changed and used to work
when I was
running with SL5.7.
Any ideas?
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
*Pierrick Hanlet*
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
snmp error Pierrick Hanlet
Prev: Record timestamp does not update (Debian Linux only) Michael Ritzert
Next: Re: Record timestamp does not update (Debian Linux only) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: snmp error Pierrick Hanlet
Next: Re: snmp error John A. Priller
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
