1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with synApps installing
Date: Mon, 22 Sep 2014 14:30:04 +0300
Hello and thank you in advance for the help.
I am trying to install synApps on my Linux machine and I encountered an error when I used 'make' ( 'make release' ran okay ).
Inflating database from ../ioc.template
msi   -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp
/bin/sh: msi: command not found
make[4]: *** [../O.Common/ioc.db] Error 127
make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
make[1]: *** [iocAdmin.install] Error 2
make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
[root@Epics support]#
I think error 127 comes from a missing compiler, but I can't figure it out, is bash trying to use a command 'msi'? but isn't that windows related?
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
RE: Problem with synApps installing Mark Rivers
Prev: Re: EDM priya tiwari
Next: RE: Problem with synApps installing Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Building EPICS base in Windows mreza
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
