1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with synApps installing
To: Vlad Andrei Rusu <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 22 Sep 2014 11:32:56 +0000
msi is an EPICS extension that converts database files.  You can download it from the EPICS Extensions Web page.  Put the "epics/extensions"/bin/linux-x86_64 directory in your path.
From: [email protected] [[email protected]] on behalf of Vlad Andrei Rusu [[email protected]]
Sent: Monday, September 22, 2014 6:30 AM
To: [email protected]
Subject: Problem with synApps installing
Hello and thank you in advance for the help.
I am trying to install synApps on my Linux machine and I encountered an error when I used 'make' ( 'make release' ran okay ).
Inflating database from ../ioc.template
msi   -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp
/bin/sh: msi: command not found
make[4]: *** [../O.Common/ioc.db] Error 127
make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
make[1]: *** [iocAdmin.install] Error 2
make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
[root@Epics support]#
I think error 127 comes from a missing compiler, but I can't figure it out, is bash trying to use a command 'msi'? but isn't that windows related?
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
E: [email protected]<mailto:[email protected]>
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
Problem with synApps installing Vlad Andrei Rusu
Prev: Problem with synApps installing Vlad Andrei Rusu
Next: build shared library using static library Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
