1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Python Question
To: <[email protected]>
Cc: [email protected]
Date: Wed, 1 Oct 2014 14:34:26 +0000
> Out of curiosity, why not use generators and yield as
> coroutines or the asyncio module?   I think that using
> these standard python solutions for coroutines and
> threads might greatly simplify things for you.
One important difference is that any time an asyncio "coroutine" calls a function (really a generator) that might wish to suspend it will have to use the "yield from" syntax.  This means that
	x = caget(pv)
	caput(pv, f(x))
would have to be rewritten as
	x = yield from caget(pv)
	yield from caput(pv, f(x))
I suppose this has the advantage of making possible suspension points clearer, but otherwise it looks pretty unsightly to me.  In particular, this means that *any* Python that wishes to perform channel access suddenly needs to transform itself into a generator, which affects how it is called, and so on.
However, asyncio clearly merits a much closer look.
RE: EPICS Python Question michael.abbott
EPICS Python Question Elder Matias
Re: EPICS Python Question Kasemir, Kay
Re: EPICS Python Question Shen, Guobao
Re: EPICS Python Question Michael Davidsaver
Re: EPICS Python Question Matt Newville
Prev: Re: EPICS Python Question Matt Newville
Next: RE: EPICS Python Question michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
