1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC server on windows or access a PV
To: zunbeltz <[email protected]>
Cc: [email protected]
Date: Thu, 2 Oct 2014 22:13:06 +0200
There is a 3rd choice: create the PV in portable channel access server.
If your calculation code can be invoked with Python, be it a C extension or separate program (using subprocess module).
This can be easy to write using PCASpy[1] extension.
Best
Xiaoqiang
[1] https://pypi.python.org/pypi/pcaspy
On 02 Oct 2014, at 21:48, zunbeltz <[email protected]> wrote:
> Dear all,
> We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
> Is it easy to install an IOC server in a windows machine?
> If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
> Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
> Thanks in advance for your help.
> Zunbeltz
> Dr. Zunbeltz Izaola
> Accelerator Physics Group
> ESS-Bilbao
Re: IOC server on windows or access a PV zunbeltz
Prev: IOC server on windows or access a PV zunbeltz
Next: RE: IOC server on windows or access a PV Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: IOC server on windows or access a PV zunbeltz
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
