Hi, You could also implement really quickly an EPICS server in C# or any other .NET language which could easily serve any value you want over the network and then be read from any other EPICS client / server. Check out our documentation here: http://sourceforge.net/p/epicssharp/wiki/server/ Sincerely, Alain Bertrand Dear all,
We need to pass some values, calculated from photographs, to the EPICS network from a windows machine. Is it easy to install an IOC server in a windows machine? If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values. Is it possible to create an PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
Thanks in advance for your help.
Zunbeltz
-- Dr. Zunbeltz Izaola Accelerator Physics Group ESS-Bilbao |
- IOC server on windows or access a PV zunbeltz
Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Peter Linardakis
Re: IOC server on windows or access a PV zunbeltz
<2014>
2025
2026
Re: IOC server on windows or access a PV Zunbeltz Izaola
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
