1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC server on windows or access a PV
To: Mark Engbretson <[email protected]>
Cc: [email protected]
Date: Fri, 03 Oct 2014 09:23:57 +0200
Dear Mark,
Thanks for the information; but I think will first try to use an existing IOC server on linux.
By the way, what is NSSM stands for? I was unable to find it.
Zunbeltz
og., 2014.eko urrren 02a 22:37(e)an, Mark Engbretson igorleak idatzi zuen:
A windows soft IOC is built as part of the utility applications when you build and recent version of EPICS with windows compilers. If you download software like NSSM, you can start the soft IOC when the computer boots. You can then write simple databases of most just ai records to hold values.
Not sure what mods you might need to make if you want values persistence across reboots.
Sent from my iPad 4
On Oct 2, 2014, at 14:48, zunbeltz <[email protected]> wrote:
Dear all,
We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
Is it easy to install an IOC server in a windows machine?
If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
Thanks in advance for your help.
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
IOC server on windows or access a PV zunbeltz
Re: IOC server on windows or access a PV Mark Engbretson
Prev: RE: IOC server on windows or access a PV Bertrand Alain Gregor
Next: Re: IOC server on windows or access a PV zunbeltz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC server on windows or access a PV Mark Engbretson
Next: RE: IOC server on windows or access a PV Bertrand Alain Gregor
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
