1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: stumbled at the first softioc example
To: HaveF <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Oct 2014 11:57:26 +0000
Are you running a firewall (e.g. iptables) on your Linux system?  If so, try turning it off and see if that fixes the problem.
Also, at the IOC prompt type the command
dbl
to make sure that you really do have a record called calc:a.
From: [email protected] [[email protected]] on behalf of HaveF [[email protected]]
Sent: Wednesday, October 08, 2014 5:10 AM
To: [email protected]
Subject: stumbled at the first softioc example
Hi all,
I’m new to the epics world. I setup epics by this article<https://pubweb.bnl.gov/~mdavidsaver/epics-doc/epics-starting.html#_softioc>.
But I didn’t get pv successful. After some search, I still don’t know why.
In the article, it set the env
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
After start softIoc program, I use caget calc:a, cannot get anything
  Channel connect timed out: 'calc:a' not found.
And I also use the following command to make sure caget works, it seems OK.
 $ sudo tcpdump -i lo  -n -nn udp dst portrange 5064-5065
  02:32:13.408675 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.441478 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.505696 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.632719 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
So, I suspect the softIoc don’t listen the 5064 port.
  netstat -a | grep softIoc
but I find nothing.
What I can do now?
Thanks!
Sincerely,
HaveF
Re: stumbled at the first softioc example HaveF
Prev: Re: stumbled at the first softioc example Michael Davidsaver
Next: RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: stumbled at the first softioc example HaveF
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
