1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stumbled at the first softioc example
Date: Thu, 9 Oct 2014 09:02:56 +0800
Thanks for reading and reply ;-)
Based on @Michael Davidsaver ‘s advice, I find the solution.
I didn’t see iocRun: All initialization complete, so I just use iocInit
command in the prompt, all works fine.
I checked the sum-start.cmd again, and find I write file like this
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","mytestioc")
dbLoadRecords("sum.db","INST=calc")
iocInit
when I add 1 line at the bottom, all works fine.
I guess, maybe the problem is evoked by the newline problem(\r\n, \n thing),
or it just need a new line in that cmd file.
I don’t go deep into this problem, but record here for others who encounter the same
problem.
Btw, thanks for @Kasemir, Kay, he point out that I should use netstat
like this, because it only output the port number.
netstat -an | grep 5064
On Wed, Oct 8, 2014 at 7:57 PM, Mark Rivers <[email protected]> wrote:
Are you running a firewall (e.g. iptables) on your Linux system?  If so, try turning it off and see if that fixes the problem.
Also, at the IOC prompt type the command
dbl
to make sure that you really do have a record called calc:a.
From: [email protected] [[email protected]] on behalf of HaveF [[email protected]]
Sent: Wednesday, October 08, 2014 5:10 AM
To: [email protected]
Subject: stumbled at the first softioc example
Hi all,
I’m new to the epics world. I setup epics by this article<https://pubweb.bnl.gov/~mdavidsaver/epics-doc/epics-starting.html#_softioc>.
But I didn’t get pv successful. After some search, I still don’t know why.
In the article, it set the env
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
After start softIoc program, I use caget calc:a, cannot get anything
  Channel connect timed out: 'calc:a' not found.
And I also use the following command to make sure caget works, it seems OK.
 $ sudo tcpdump -i lo  -n -nn udp dst portrange 5064-5065
  02:32:13.408675 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.441478 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.505696 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
  02:32:13.632719 IP 127.0.0.1.52067 > 127.0.0.1.5064: UDP, length 40
So, I suspect the softIoc don’t listen the 5064 port.
  netstat -a | grep softIoc
but I find nothing.
What I can do now?
Thanks!
Sincerely,
HaveF
Sincerely,
HaveF
stumbled at the first softioc example HaveF
RE: stumbled at the first softioc example Mark Rivers
Prev: Re: TCP connection status : drvAsynIPPort J. Lewis Muir
Next: Re: TCP connection status : drvAsynIPPort Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: stumbled at the first softioc example Mark Rivers
Next: Job Opening at Helmholtz-Zentrum Berlin (HZB) Joachim Rahn
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
