It would really help to see the entire traceback, not just the final location of the crash. If you still have the core file you can get it by:
gdb [path_to_your_application] [core_file]
Brackets indicate you need to substitute your values there.
Once at the gdb prompt type
traceback
Then send us that output.
From: [email protected] [[email protected]] on behalf of Poff, Mark A [[email protected]]
Sent: Wednesday, October 08, 2014 7:44 AM
To: Hartman, Steven M.
Cc: Poff, Mark A; EPICS Tech Talk
Subject: RE: Fanout to Sub Records in a Different IOC Causes Core Dump
Hello Steven,
Unfortunately, no processing code was running when we crashed. Mark Rivers also asked about the core dump, and what OS we were using. We're on Linux, and my co-worker Steve Goff used gdb to find where the core occurred. Steve said the crash happened in camessage.c, line number 1344.
As I noted in my original message, after talking with Andrew Johnson I altered my database to not use the fanout record, thus avoiding the problem and allowing me to continue with my work. But I should be able to re-create the situation if it would help in troubleshooting.
-----Original Message-----
From: Hartman, Steven M. [mailto:[email protected]]
Sent: Tuesday, October 07, 2014 4:16 PM
To: Poff, Mark A
Cc: EPICS Tech Talk
Subject: Re: Fanout to Sub Records in a Different IOC Causes Core Dump
On Oct 7, 2014, at 3:55 PM, Poff, Mark A <[email protected]<mailto:[email protected]>> wrote:
> As an alternate we tried placing the fanout record in the Processing IOC, but that also core’d.
Since the processing IOC core dumps regardless of where you are running the fanout record, I suspect the bug is more likely to be found in your Process routine rather then in the IOC code. Have you looked at the core dump to see where the crash is occurring? If you replace your processing routine with something really simple, do you still get the crash?
Steven Hartman
- RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
- Re: Fanout to Sub Records in a Different IOC Causes Core Dump Hartman, Steven M.
RE: Fanout to Sub Records in a Different IOC Causes Core Dump Mark Rivers
<2014>
2025
2026
<2014>
2025
2026
