1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fanout to Sub Records in a Different IOC Causes Core Dump
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Oct 2014 14:53:33 -0500
Hi Mark,
On 10/07/2014 02:55 PM, Poff, Mark A wrote:
> On the EPICS project here we’ve run into an issue which we believe /may/
> point to a bug with fanout records and CA links - and we’re wondering if
> anybody else has seen this behavior.
I have just checked the 3.14 version of the fanout record, it does
support forward-linking through Channel Access with no problems for me.
If you can replicate your crash using 2 simple IOC databases without any
subroutine records I would be very happy to test your databases and try
to replicate your results.
If you can't, take a look at how much stack space your Process1_routine
subroutine needs, running out of stack space is one possible cause for
this kind of strange behaviour in addition to the usual kinds of
problems. A full stack trace for all threads when the crash happens
would also help us help you (type 'thread apply all bt' in gdb).
- Andrew
RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
Prev: RE: MCA and WAN connection Mark Rivers
Next: Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
