Hi Mark,
> If you can't, take a look at how much stack space your
> Process1_routine subroutine needs, running out of stack space is one
> possible cause for this kind of strange behaviour in addition to the
> usual kinds of problems. A full stack trace for all threads when the
> crash happens would also help us help you (type 'thread apply all bt'
> in gdb).
Keep in mind that the stack trace could be corrupted. You might want to
run with a trivial subroutine for testing.
In addition to that it's always a good idea to write a short test
program that calls the subroutine function with some test values. You
can run this test program with
valgrind --tool=memcheck <your_test_program>
to see if it is writing to memory it should not write to.
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
- Re: Fanout to Sub Records in a Different IOC Causes Core Dump Steven
Re: Fanout to Sub Records in a Different IOC Causes Core Dump Andrew Johnson
Re: MCA and WAN connection Maren Purves
<2014>
2025
2026
<2014>
2025
2026
